    Feb 2003
    Rochester, NY
    What makes the Progression hull any different from other Vee bottoms when run at these high speeds? They are all walking on a tight rope.
    You are correct in that most all pad bottom vee hulls - driven at the limit - are right on the edge. From personal experience though, I'll say that the thing that's different about Progression hulls is that they run well in snot (as you've seen in my pics), ride decently and most importantly, they last. Mine's a 1992 and the very first vacuum bagged 22 they ever built. Just look at the pic and see what kind of shape it's still in.
    1992 Progression 22
    Mercury Racing 250R
  2. Likes goneby, AZMIDLYF liked this post
  3. #2972
    Jul 2004
    Connecticut
    The 2019 Hallet 210 build is coming along out West. This hull design has slammed through rough water for over 25 years with I/O power. Now rigged with a Mercury 450 and pushing a full 8' beam it will be interesting to see what speed Nordic can get it to out of the box.
    Attached Thumbnails Attached Thumbnails 2019Hallet21OBWhite.jpg   rIO1tkEqTeOJObaDAMqo1g.jpg
  4. Likes Baja170 liked this post
  5. #2973
    PARADISE /Naples
    You in lake Ontario there looking good.
  6. #2974
    Feb 2003
    Rochester, NY
    Quote Originally Posted by CUDA View Post
    Thank you for the kind words. That particular photo was taken on nearby Seneca Lake, but it was equally snotty.
    1992 Progression 22
    Mercury Racing 250R
  7. #2975
    PARADISE /Naples
    Back in 1978 I bought a house on Little Sodus Bay Fairhaven, I loved that area. (except winter) Lots of migrating ducks and geese.
  8. #2976
    Lake Coochiching, Ontario
    The Hallet doesn't seem to have a pad. It will take some fancy driving to go 100.
  9. #2977
    Jul 2004
    Connecticut
    Quote Originally Posted by David View Post
    Many would agree, and also dragging that big case on the 450R. Old school straight 18 degree V on the Hallet 210.
  10. #2978
    Mar 2004
    Newport Beach Ca.
    2019 Labsport 21 This is a new model F-2 legal 21' 4" running surface. 4th out of the mold 1st in the states. She runs very well with Ballast in the rough conditions
    and airs out very quick in the smooth. With just a few Races under our belt still working on set up and props for Race conditions with Skier. I plan to get a couple taller Props to test for top speed solo runs. Very happy with all around use as play and race boat she planes out very low speed when pulling the Grandkids skiing.
ID:	454564Click image for larger version.
ID:	454565Click image for larger version.
ID:	454566Click image for larger version.
  11. Thanks Greg G thanked for this post
    Likes AZMIDLYF liked this post
  12. #2979
    Jul 2004
    Connecticut
    Quote Originally Posted by 28SkaterCa. View Post
    2019 Labsport 21. This is a new model F-2 legal 21' 4" running surface. 4th out of the mold 1st in the states. She runs very well with Ballast in the rough conditions and airs out very quick in the smooth. With just a few Races under our belt still working on set up and props for Race conditions with Skier. I plan to get a couple taller Props to test for top speed solo runs. Very happy with all around use as play and race boat she planes out very low speed when pulling the Grand kids skiing.
    92 mph is impressive right out of the box, especially considering they've only built a handful so far. Thanks for the info. Looks like your co-pilots are ready!
    Attached Thumbnails Attached Thumbnails LabSport21.JPG   Labsport21side.jpeg   Labsport21WhiteArcher.JPG   Team222Labsport21300R.jpg   Labsport21300RInterior.jpg
    rr.jpg   Labsport21300RRearSeat.jpg   66257241_.jpg   Labsport21300RSteering.jpg   Labsport21GPS92mph.jpeg
  13. #2980
    Jul 2004
    Connecticut
    https://www.facebook.com/watch/?v=1015560588784399
  14. #2981
    Jul 2004
    Connecticut
    Tis the Season ............ to start building up The List with V8's for next year -
    2020's Fastest SOB Rough Water Hulls
    Powered with stock Mercury 300R 4.6-liter naturally aspirated V8 (6400RPM, No Dyno Yet)
    #1 Labsport 21 – Confirmed 94MPH Driver 28SkaterCa
    Fastest SOB Hulls Available For Purchase New In 2019....All Boats Powered with a stock Mercury 300XS (306HP and 6400RPM Limiter)
    #1 Tuff 21 kevlar hull-890lbs– 20’8” Long, 7’7” Beam - 22 degree deadrise + 7 1/2" pad - Confirmed 105.9MPH Driver Blake Sewell Canada
    #2 Bernico F2 21 standard hull-727lbs– 21’4” Long, 6’3” Beam - 24 degree deadrise + 14” pad - Confirmed 98.1MPH Driver Dave Van Steelant
    #3 Progression 22 standard hull-948lbs– 22’1” Long, 7’8” Beam - 24 degree variable deadrise + 7" pad - Confirmed 94MPH Driver goneby
    #4 Velocity V7 21 standard hull-682lbs– 21’4” Long, Unknown Beam – 22 degree deadrise + Unknown pad width - Confirmed 92MPH Driver 28SkaterCa
    #5 Sutphen 21 standard hull-1325lbs– 20’9” Long, 7’2”Beam - 20 degree variable deadrise + 3" pad – Claimed 88MPH Driver Unknown (525 ran GPS 93.4)
    #6 Nordic Crossfire 21/SR-21 standard hull-1475lbs– 21’ Long, 7’1” Beam - 18 degree deadrise + 9" pad - Confirmed 86MPH Driver wildone
    And the fastest of the no longer produced hulls....with power noted
    #1 2002 Intimidator 21 -- Deadrise=22 Degrees + 6" pad. Confirmed 104.6MPH – Stock Merc 15” 300X(325HP) - Driver Trimmed Out15
    #2 1985 Velocity 22 Stepp “Old Style Deck” -- Deadrise=22 Degrees + 12" pad. Confirmed 97.1MPH – Stock Merc 20" 300X(325HP)- Driver B kNo023
    #3 1986 Superboat 21 Classic -- Deadrise=22 Degrees + 6" pad. Claimed 97MPH - Stock Merc 20” 300X(325HP)- Driver hoser
    #4 1976 Challenger 21 -- Hull 1350lbs Deadrise=21.5 Degrees. Confirmed 90MPH - Yamaha 250 HPDI Phase III (326HP) - Driver Jamescole
    #5 1990 Activator 21 -- Hull 1475lbs Deadrise=22 Degrees + 5 1/2" pad. Confirmed 84MPH – Stock Yamaha 250 Ox66 (256HP) - Driver dnelson964
    #6 2012 Velocity US 220 -- Hull-1895lbs – 21’6” Long, 7’11” Beam - 22 degree deadrise + 12" pad. Confirmed 83.5MPH – Merc 300XS - Driver aaronmt73
  15. #2982
    Mar 2010
    Alberta
    21’ Checkmate Pulsare LD, 300xs, regular layup 1300lb hull. 98.1 mph, Driver Randy Corson
    https://m.youtube.com/watch?v=H_90ekKxbfQ
    08 Checkmate 2100br 250xs
  16. #2983
    Dec 2019
    Spring Lake MI
    Has the 24 tuff not went 114+ with a 300x?
  17. #2984
    Jul 2004
    Connecticut
    Quote Originally Posted by altamate View Post
    You are forgetting this one.
    https://www.screamandfly.com/showthr...peed!-98-1-mph!
    Specs. weight, length, beam, can be found on the Checkmate website,
    The Checkmate Long Deck was discussed a number of times in this thread.
    The consensus was that the Pulsare could not take the rough water that the others on "The List" could. This was due to several factors. Based on all that info, it was never able to make the cut. Pulsare fans can do a key word search within this thread on Checkmate. This will let you see the various points of view.
  18. Thanks altamate thanked for this post
  19. #2985
    Jul 2015
    NC/TN/KY
Page 199 of 271 FirstFirst ... 99 149 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 249 ... LastLast
