Results 1 to 15 of 26
    Jul 2012
    Eldersburg, MD
    2.5 promax fuel rail o-rings
    Anyone have any information on alternative o-rings that can be used when things are apart? Looks like I had some seeping going on from the 2 aluminum tubes that feed the fuel rail from the VST. Would also be nice to have info (part #’s)of the other o-rings involved when injectors are out for a cleaning.
    Aug 2012
    beaumont, tx
    call brucato they have some
  3. Likes tux974, Dave Strong liked this post
    You can also try Fuller Marine (Vnemous) on here or a local injector cleaning shop if you have one.
  5. Likes Dave Strong liked this post
    What Cody and Tony said, use the correct parts. nothing worse than a fire under the cowl out on the water.
    15029 - O-RING AND SEAL KIT ---- LIST PRICE $527.26 LOL
    I go to a local seal and gasket distributor with a dollar bill and get the o rings and change back.
  8. Likes W2F a V-King, 90 5.0 liked this post
    Aug 2012
    beaumont, tx
    ive tried some metric and standard orings from local auto parts store.. they didnt hold up
  10. Likes Dave Strong, tux974 liked this post
  11. #7
    Quote Originally Posted by texasvector View Post
    Cody!
    I strongly recommend to use fuel/ethanol/alcohol complaint. Best to locate an injector shop....JMPO!
    Not to mention the PITA to disassemble a plenum to change a leaky silly O ring......SOB....
  12. Likes texasvector, Dave Strong, 90 5.0 liked this post
  13. #8
    The real ones are usually green, brown or blue. And come in packs of 50 or 100 ..
  14. Likes Dave Strong, 90 5.0, Capt.Insane-o liked this post
  15. #9
    How about a part number or a source to purchase Mr Chaz??!!....
  16. Likes Dave Strong liked this post
  17. #10
    Quote Originally Posted by tux974 View Post
    Mr. Tee,
    Unfortunately, Mercury used a few different injectors and fuel rails over the years. I'm not familiar enough with the 2.5 Pro Max to know exactly what they used. It would be irresponsible of me to take a guess ...
    If you know the stem diameter, depth and width of notch in the stem and rail I.D. then it's easy to pick from the chart ....
    Lots of sellers on Flea-bay. Some of the shops run specials or sell overstocked items.
  18. Likes Dave Strong, 90 5.0 liked this post
  19. #11
    That is so very nice to NOT be irresponsible.......
    Just a little bit of info.
    PM injectors are the same pink tip as the 300X and the 300PM white tips are the same size just a color change.
    If you know the correct pink tip size for the X it will save me work... ...and help us all.....
    Chaz, I would be a bit concerned about buying them from fle-bay. I like to do these plenum 1 time! Certainly do not want to find out that the person on fle-bay sold me something that was round and rubber but not good..........for fuel.... I would prefer an injector vendor as a source.
  20. Likes Dave Strong liked this post
  21. #12
    Green are a/c orings..you want the brown o ring.
  22. #13
    Capt, funny thing Mercury has the green rings for injectors, black for rail aluminum tubes and vst hose adapter, go figure....
    Hopefully these type of threads and info are helpful for some!
  23. Likes Dave Strong liked this post
  24. #14
    I was making a funny ..ill stop by zatkoff and get the sizes of them. They have them presorted for the vst and airbox. In Viton.
  25. Likes Dave Strong liked this post
  26. #15
    If i remember correctly the injector o-rings that came in the Merc rebuild kit for My Bridgeport were blue.
  27. Likes tux974 liked this post
  1. 3 liter Mad EFI intake, Fuel ECM, and Fuel Rail
    By Mr. Demeanor in forum Misc. Parts and Accessories
    Last Post: 09-24-2018, 02:23 PM
  2. 300 Promax Fuel rail
    By strongback in forum Misc. Parts and Accessories
    Last Post: 09-03-2014, 09:19 PM
