Results 1 to 15 of 24
10-20-2019, 09:39 PM #1
10-20-2019, 09:59 PM #2
Bfh
Azure AZ259, 8.1
B.loco60 liked this post
10-20-2019, 11:14 PM #3
take it to a propshop that does it every day and get some lunch
most overnite successes usually take at least 10 years
Certified turd polisher,
ssv1761982 thanked for this post
10-21-2019, 08:30 AM #4
I've got a 6"x 6" block of wood about a foot long that I hole sawed about a 3" hole down as far as the saw would reach .. about 2 - 2.5" deep. I chizeled out the center plug and I use the block to rest props in while I press hubs in and out. The hub only needs to move about an inch before I hear it fall into the "basket".
10-21-2019, 09:06 AM #5
I use the E-Z shift ( or whatever they call the new ones) hubs like the one in post # 1.
10-21-2019, 09:12 AM #6
6000 RPM
- Aug 2015
- Southeast
- 1,279
- 139
- 122
- 58
- 787
I use a bottle jack, socket, and a couple short 2x4s underneath the boat trailer. Prop shop or the bushing tool above would be better. These hubs are called SSR I believe. I quit using since it was such a pia to get them out.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship" Sold
Blazer 650 Pro Tour
30ft Cobra with Triple 280's
ssv1761982 liked this post
10-21-2019, 05:02 PM #7
5000 RPM
- May 2012
- tenn
- 219
- 12
- 17
Let us know how it goes, looks like a bear to press out without hurting something.
10-21-2019, 08:07 PM #8
5000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
I use the rubber Rubex hubs. To get them out I've stuck the prop in the freezer for a while to shrink the rubber hub. Then pound it out.
10-22-2019, 07:08 AM #9
or stop by the shop when you're up this way and I'll have it out ina minute while you wait...
10-25-2019, 04:40 PM #10
10-25-2019, 07:05 PM #11
Team Member
- Lake Coochiching, Ontario
- 8,439
- 43
- 399
- 664
- 2113
- 6 Post(s)
I bought a second SSR hub for a second prop. Seemed easier than getting the first one out of the Trophy. The second is stuck in a drag 4.
10-26-2019, 07:31 AM #12
10-26-2019, 07:36 AM #13
6000 RPM
- Jul 2011
- Gloucester, VA
- 1,320
- 19
- 90
- 180
- 344
That hub doesn't need to be "pressed" out. They are just tight amd get stuck. An appropriately sized socket, a soft faced dead blow hammer, and a sturdy surface will make easy work of it.
10-26-2019, 07:44 AM #14
Team Member
- 8,439
- 43
- 399
- 664
- 2113
- 6 Post(s)
they don't get damaged coming out?
10-26-2019, 10:23 PM #15
6000 RPM
- Jul 2011
- Gloucester, VA
- 1,320
- 19
- 90
- 180
- 344
Formula One PROP press release
By Wayne Worthy in forum Racer's HangoutReplies: 18Last Post: 04-27-2010, 12:34 PM -
Press "1" if you want to be an American. Press "2" if you want to go home.
By Capt.Insane-o in forum The Scream And Fly LoungeReplies: 3Last Post: 01-23-2009, 10:32 PM -
where to buy a press??
By wing nut in forum General Boating DiscussionReplies: 13Last Post: 01-26-2004, 07:01 PM -
Water Press and Fuel Press guages
By signpro in forum Technical DiscussionReplies: 3Last Post: 08-22-2002, 01:18 PM
