Results 16 to 27 of 27
Thread: Electronic Ignition Conversation
10-17-2019, 04:36 AM #16
"CC" means 150 block. The "1" is month made. "13" should be year, but that is not a 2013 motor.
10-17-2019, 06:33 AM #17
Yep. Cc is usually 150 xr6. If memory serves correct Ur mota is a 96. Ur mid look like 01 xr6. 2-5-96 is build date
DEN thanked for this post
10-17-2019, 04:09 PM #18
5000 RPM
- May 2011
- OK
- 247
- 57
- 17
What IS the powerhead then? 150 what? a 1996 XR6? any way to tell what model powerhead this is?
Nada lists 7 1996 merc 150HP that year, including a XR6. All the EFI's can be thrown out the window, leaving 4 to choose from.
I have no idea even to guess. But I'm sure their are some differences with the 4 models to choose from.
Most likely, all use the same parts with maybe different internals. (?) Serial # does me no good to research the powerhead.
Would be nice to know for sure tho.
If you think this is fun, wait til next weekend!
10-17-2019, 04:14 PM #19
10-17-2019, 05:10 PM #20
5000 RPM
- May 2011
- OK
- 247
- 57
- 17
yes,, mine has the same plug same place, BUT there are no numbers or markings on mine.
so mine is a 96 XR6?
10-17-2019, 05:30 PM #21
I do. Believe cc block was xr6 150. Not 100% but 90. Theres a serial behind throttle arm where 2 block halves meet runnin vertical. Unless it's a replacement block. On those sum didnt have #s
10-17-2019, 06:14 PM #22
5000 RPM
- May 2011
- OK
- 247
- 57
- 17
That exactly where I found this "CC 1 13"Theres a serial behind throttle arm where 2 block halves meet runnin vertical
10-18-2019, 04:07 AM #23
Im not sure what you are trying to figure out. Your motor is a "mixed bag". Very obvious that it has a promax divider plate. Its nearly impossible to tell exactly what you have from the outside. Most parts are interchangeable on 2.0, 2.4 and 2.5 motors. Your motor could be a 2.0 or 2.5.
10-18-2019, 05:11 AM #24
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
The stock ignition is good for over 300 hp and 10k RPM. Look elsewhere for modifications...
powerabout liked this post
10-18-2019, 05:33 AM #25
10-27-2019, 12:33 PM #26
5000 RPM
- May 2011
- OK
- 247
- 57
- 17
Hey guys, Sorry for the late reply here. I just got back from Japan, work related.
I do thank each and everyone of you whom cleared up my confusion here.
David>>>>>
11-25-2019, 10:23 PM #27
5000 RPM
- May 2011
- OK
- 247
- 57
- 17
An update on what I have found out. Merc, you are right on track with this one.... after hours of researching. my mid IS 2001 XR6 and someone has change out the PH.ep. Cc is usually 150 xr6. If memory serves correct Ur mota is a 96. Ur mid look like 01 xr6. 2-5-96 is build date
Build date 2-5-96 which is stamp on the block. "CC" is the stamp code for and 150hp XR6. so with this confirmed information, I have concluded the serial #s 0G303046 thru 0G760299
At least now a can get parts when needed and should not have to worried if they will fix or not.
Thanks again for all y'all help!
Also a huge thanks to Mach351, here @ S & F.Last edited by DEN; 11-25-2019 at 10:25 PM. Reason: typo
Mercury Tech: Electronic ignition HELP needed please...
By Iwanngofast in forum Technical DiscussionReplies: 0Last Post: 07-03-2014, 03:26 PM -
Problem with electronic ignition(pertronix)
By mdsv16 in forum Technical DiscussionReplies: 7Last Post: 05-12-2013, 01:19 PM -
Problem with electronic ignition ( pertronix)
By mdsv16 in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 06-11-2008, 08:04 PM -
Electronic Ignition
By JTS Racing in forum Technical DiscussionReplies: 2Last Post: 11-11-2001, 10:26 AM
