Results 16 to 24 of 24
Thread: Efi options
10-05-2019, 09:58 AM #16Larry Gempp Jr.
10-05-2019, 02:24 PM #17
Can you give me an idea of what that setup would cost?
hold on and hope for the best
10-06-2019, 04:06 AM #18
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,333
- 1067
- 412
- 4726
- 2174
- 9 Post(s)
slide if you race otherwise dont go there
AZMIDLYF liked this post
10-06-2019, 11:04 AM #19
there are cheaper options
but like i said what is your experience level?
10-06-2019, 11:10 AM #20
My experience is limited at best. I would have to have Monty, Bush or Sam set it up for me. Just trying to figure out my best option and get a number to shoot for to see if it is a viable option for me.
10-06-2019, 11:24 AM #21
the less conversion the better $$$$$$
you can keep an eye out in the parts buy and sell section for the fuel injection parts
and possible a brucato unit
this should not break your wallet and still give the benefit of easy control
10-06-2019, 05:19 PM #22
Boy it varies based on what ignition and electronics. The rotator was around 10k with DBR pistons/sleeves. 5-7k for heads, slide, trigger wheel, flywheel, egt studs, injectors, coil packs. The electronics can range from 3-10k. I have a backup drop on 3.3L Id be willing to sell with Monty Plenum for 13k, or 14k with slide plate. Only 8 passes on it.
Larry Gempp Jr.
10-06-2019, 06:01 PM #23
Another option now for the intake is the g2 plenum you can use throttle by wire or with slight modifications put any ls style throttle on top with tps.. when I get my current setup up and going I plan on bolting the g2 plenum on with a 90mm throttle to see what the difference is from the slide..
10-06-2019, 08:24 PM #24
Options..
By 40hpmariner in forum General Boating DiscussionReplies: 5Last Post: 12-16-2010, 08:31 PM -
OMC 2:1 gear options
By Clint in forum Technical DiscussionReplies: 1Last Post: 12-11-2010, 06:19 AM -
steering options
By wanagofass in forum Props, Setup, and RiggingReplies: 1Last Post: 09-03-2010, 12:32 PM -
UPS run-around. Any options?
By DaveR in forum General Boating DiscussionReplies: 17Last Post: 11-08-2002, 10:57 PM
