Results 16 to 30 of 33
    Plainville, CT
    Given two equal engines, one with vertical front and one with horizontal, any rough guess what the difference would be in:
    1) low end torque, and
    2) rpm
  2. #17
    Jul 2012
    Lufkin, Texas
    i've never run a horizontal 2.0 so I'm not sure...
  3. #18
    Dec 2001
    Hoz - more..... that's why the later ones have... plus modula mannfactering......
  4. #19
    Sep 2017
    Ashland city tn
    I was just talking to a member earlier today ,that bought a motor from me , bout how we like take older 2.0 ,change to horiz and add finger ports and stick on a 600lb bote. B nice rig
  5. Likes nitro_rat liked this post
  6. #20
    Jul 2012
    Lufkin, Texas
    If I had access to a mill I would probably cut some finger ports. I'm not going to try to do it by hand. I could probably do 5 good ones per block. No luck finding anyone who's willing to cut one for me...
  7. #21
    Sep 2017
    Ashland city tn
    Ya I think that's a ton of work. prob take gud long while
  8. #22
    Dec 2001
    no need to finger......just clean up wat ya got.....Exust up and smooth the hole......Hozzz is bigggy
  9. #23
    Feb 2003
    Auckland - New zealand
    Yea did the finger port thing way back, late 80s, on a Merc 2 liter , drilled holes in pistons etc, was running a tunnel on the circle track. Way more mid range not a lot extra at the top. Was lucky my machine shop had this old time mill that could drill all the angles, and an operator who knew his stuff. Even had a Merc six pack carb setup on it in the end. Should never of sold them.
    Peter Thomas
  10. Likes nitro_rat liked this post
  11. #24
    Jul 2002
    FT WORTH, TEXAS
    here is a cekrite i learned i installed wmv arms and linkage on a set of wh 22's they worked perfect
  12. Thanks nitro_rat thanked for this post
    Likes eli, nitro_rat liked this post
  13. #25
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by TEXAS20225 View Post
    I'll remember that one!
  14. #26
    Sep 2017
    Ashland city tn
    The wmv rod looks better to haha, that's exactly what I did with my wh. The aluminum/ metal gives it nice touch
  15. Likes nitro_rat liked this post
  16. #27
    Plainville, CT
    Are finger ports the same as idle relief slots, or what are they? What are they supposed to do?
  17. #28
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Glastron1987 View Post
    No, finger ports are an additional intake port, like a groove in the cylinder wall accompanied by another hole in the side of the piston. Idle relief slots are a raised portion of the exhaust port that bleed off cylinder pressure (more at low rpm than high due to piston speed) that helps smooth out engine idle.
  18. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  19. #29
    Plainville, CT
    Thanks for the explanation. I'm trying to understand the porting a little better. I have 2 V6's running now... a 1988 XR4 (2.4L) and a 1994 150 (2.0L). Have only been out in the 2.0L once so far, but is seems to idle and run really great. Maybe not as much torque as the XR4, but seems to idle better and does seem to want to run fast. It also does have the exhaust relief slots, but probably not the finger ports.
  20. #30
    Jul 2012
    Lufkin, Texas
    Not familiar with the "fat block" 2.0's. No consumer 2.0's had finger ports. Maybe some of the racing ones, I don't know. Your XR4 should have them though...
  21. Thanks Glastron1987 thanked for this post
  1. 2.0 vertical front mystery motor
    By dtmeeks in forum Technical Discussion
    Last Post: 07-08-2019, 09:05 PM
  2. Merc vertical front half for 2.0
    By Keaten in forum Misc. Parts and Accessories
    Last Post: 12-17-2017, 04:06 PM
  3. Mercury Tech: Vertical front half woes
    By gotboostedvr6 in forum Technical Discussion
    Last Post: 10-09-2015, 10:54 AM
