Results 1 to 15 of 37
Thread: Mariner 200 EFI will not start
08-09-2019, 05:40 PM #1
Junior Member
- Aug 2019
- North carolina
- 14
Engine cranks and almost starts just don’t fire up
engine will run when I supply fuel with spray bottle
Boat sit couple years. Cleaned fuel system. Got priming bulb in fresh tank of fuel
removed vst and cleaned
removed regulator cleaned screen
removed high pressure pump cleaned screen
changed fuel lines
changed fuel water separator
fuel pressure is at 39 psi when electric pump cycles for 30 sec
low psi pump keeps vst full, as anytime I remove hose from vst fuel flow/psi is there
had injectors cleaned and checked by brucato
***engine will run when I supply fuel mix with spray bottle
i don’t think injectors are spraying/injecting
rail fuel pressure is good while cranking, regular pops off at around 38 psi
how do I check voltage at injector plug?
as I have battery voltage at red wire at injector plug
08-09-2019, 05:41 PM #2
Junior Member
- Aug 2019
- North carolina
- 14
0g131201 is serial #
08-09-2019, 05:55 PM #3
I'm no efi guy but there are many here who r ... buttttt... sounds like comp ecu or what ever it is , driver isnt firing all injectors. Someone will respond with ur info. I have a manual. I'll look see if I can locate sumthin.
Welcome s&f
08-09-2019, 06:04 PM #4
Junior Member
- Aug 2019
- North carolina
- 14
Merc
i have a Manual, but maybe I’m missing something.
but I can’t find how to check injector harness with a
engine not running. I guess I need check voltage at plug
while cranking
08-09-2019, 06:18 PM #5
I wish I had more info to help ya but I dont , I just fool with carby, u should have trouble shoot in fuel part manual and how to test
08-09-2019, 06:20 PM #6
Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
Seems I recall reading kill switch interrupts injectors circuit.
i do have a Merc ecm for that engine. Clay
08-09-2019, 06:50 PM #7
6000 RPM
- Jul 2011
- Gloucester, VA
- 1,326
- 19
- 90
- 180
- 345
08-09-2019, 07:58 PM #8
Junior Member
- Aug 2019
- North carolina
- 14
Ok guys I can spray some mix in air
box. Crank and it will start and idle fine now.
but it want start on it’s own. I checked
compression on all cylinders and all around 120psi
08-09-2019, 11:28 PM #9
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
i just had one doing the same thing guy brought it from another shop they blamed injectors, after checkin everything turn out to be bad injector harness in side plemun
08-10-2019, 09:29 AM #10
5000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Injectors were recently cleaned, or before it sat for 2 years? If they sat unused that long they are probably gummed up.
08-10-2019, 10:58 AM #11
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
What is cranking voltage most merc computers need 9.6 to even turn on. So even with enough to spin the pc will shutdown.
I always start with batteries on no starts.
08-10-2019, 07:06 PM #12
Junior Member
- Aug 2019
- North carolina
- 14
Injectors have been cleaned/test this week. New battery with 14 volts
Engine cranks no start. I spray a little mix in
intake and it will then start and idle
08-10-2019, 07:24 PM #13
Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
Temp sensor with 3 wires on cyl head tells ecu when
to run rich for cold engine. Maybe it’s saying its at operating temp
and is too lean for starting.
08-10-2019, 07:49 PM #14
Junior Member
- Aug 2019
- North carolina
- 14
Triton
I disconnected both tan/black stripe wires from
temp sensor. Engine fires right up every time.
Looking at troubleshooting that sensor now
08-10-2019, 08:13 PM #15
Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
With it disconnected it should run about 40% richer than normal.
Those sensors are not very expensive, replaced mine last year.
KIRCHNER thanked for this post
1998 Mariner Optimax 225 DDI won't start
By jluchuk in forum Technical DiscussionReplies: 1Last Post: 08-13-2018, 06:37 PM -
135 mariner hard to start when cold
By hydrostream300 in forum Technical DiscussionReplies: 7Last Post: 01-26-2012, 04:22 PM -
'98 Mariner Magnum 175 EFI hard to start
By MarkMuzzy in forum Technical DiscussionReplies: 3Last Post: 08-25-2011, 07:52 AM -
1994 Mariner 175 EFI Cold Start Failure
By Fred Reed in forum Technical DiscussionReplies: 7Last Post: 08-17-2005, 08:13 PM -
Mariner 200efi wont start
By VectorPat in forum Technical DiscussionReplies: 3Last Post: 10-01-2002, 10:17 AM
