Results 16 to 30 of 33
    TX......somewhere?
    after you posted another pic on your other post don't believe that to be a cle?.. looks ta be early factory.. does it have for better words, a "trough" on both sides that look like it will better water direction to tha little inlets?.... if so it probably came on tha original motor/clamp/down housing.
  2. #17
    5 Post(s)
    stock modvp's were carb motors.
  3. #18
    TX......somewhere?
    that serial number doesn't come up as mod-vp.. doesn't even come up as hi perf.. jus 2.4 (merc. site).. but its definitely early hi perf efi..
    mod-vp... efi.. they did in tha '87 horn motor.. don't know 'bout tha earlier up-draft?
    https://www.mercruiserparts.com/merc-mod-vp-efi
  4. #19
    Jul 2012
    Lufkin, Texas
    I'll be the first to admit I don't know everything. I'm usually not surprised by Mercury V6 outboard stuff but there's not any hi-po stuff around here. Somebody school me on the "updraft" front...
  5. #20
    TX......somewhere?
    look at tha pics of his motor.. pre horn tha front plenum has a big hole and throttle plate on tha bottom for air intake... sucks air "up" thus tha "up draft".. its sometimes mistakenly called a down draft..
  6. Thanks nitro_rat, Merc 2.5 thanked for this post
  7. #21
    Jul 2012
    Lufkin, Texas
    tlwjkw, I've been a member here for 7 years + and lurked for several years before that. never seen or heard of this before and I know how ti search...
  8. #22
    TX......somewhere?
    picture of tha thing with original ecu… some of us here are gettin' "really old"..
  9. Thanks nitro_rat thanked for this post
    Likes nitro_rat, Capt.Insane-o, Baker343 liked this post
  10. #23
    Jul 2012
    Lufkin, Texas
    Would it be a Bridgeport or oval?
  11. #24
    TX......somewhere?
    I don't remember any efi's back then (pre horn) being tha oval port?.. later, anything with tha bleed stuff could have been either and no way ta tell from outside appearance that I recall.. don't remember much about tha "hot rod" oval port (efi and carb) till around '87 up...
    if they didn't have bleed nipples at cyl's 99.9% chance of it bein' a BP as tha oval port is really justa naked production block..
    they also built a "formula" motor that was seven petal carb BP that gets mistaken for a mod-vp... its not a well known motor...
  12. Thanks nitro_rat thanked for this post
    Likes nitro_rat liked this post
  13. #25
    5 Post(s)
    TX......somewhere?
    think that one will be either tha efi or tha 5 petal carb motor maybe?.. tha seven petal carb came straight off tha "TRUCK" (like tha laser injected BP).. was originally a lefty, powerhead only... been a very long time ago...….
  15. #27
    Oct 2013
    east tennesse
    Well Let,s start with lower Yes 2 eye lits above center of c/l center line , mid single ram w j1171 pump, have not check other marking
    but will , no pulse lines on block, aluminum old school flywheel , has hour clock reading 136 but i have 2 hours on it.
    That i know, your guess, heads 1 pc ??
    Thanks A bad ass sounding engine, need to get on a lite boat.
    Need compression numbers, see what we have Thanks again O yes told this engine is from Tennessee and S&F
  16. #28
    Sep 2015
    Twin Cities, Minnesota
    My 85 Mod VP doesn't have bosses on the top cylinder and its "naked"
  17. #29
    Jun 2014
    Midwest
Name:	merc block 002.jpg
ID:	446340Click image for larger version.
Name:	merc block 003.jpg
    Have had A few of these Engines that resemble this Block
    All were what has been identified as an updraft.
    They all were single Port 2.4 liter
    Ran extremely well with the 2 liter Race box on them
    This particular block if memory serves has been painted also
    Did not start out Painted
  18. #30
    Oct 2013
    east tennesse
    Thanks xp300 great pic,s
  1. Replies: 2
    Last Post: 07-10-2015, 09:11 PM
  2. 1985 Bridgeport EFI on 1985 STV Shovelnose prop question
    By MISSING in forum Props, Setup, and Rigging
    Last Post: 02-28-2012, 03:53 PM
  3. xp 200 1985?????????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-15-2009, 12:25 PM
  4. 1985 Xr2
    By jjmalkow in forum Technical Discussion
    Last Post: 03-04-2007, 04:42 PM
  5. 1985 omc v4
    By ram4fun29 in forum Technical Discussion
    Last Post: 06-01-2002, 09:02 PM
