Results 1 to 15 of 19
    Mar 2009
    Hot Springs, AR
    Good water flow/low water pressure
    I've got an 86 2.0 150 that I put on an 85 2.4 200 adapter plate. Same lower, same water pump, just ported the exhaust to match. Went from making 25 psi at idle to 10 and now it drops when I bring the rpm's up. Any insight on what's going on? I'm at a loss and have tried plumbing it every which way without pulling the power head.Click image for larger version.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    82 Hydrostream Vandal Comp
    ^(project that needs a new home)
    Mar 2009
    Hot Springs, AR
    Water pump has less than 2 hrs on it and made 20+ psi on old power head at idle. It has a ton of flow just no psi.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    If you made 20 at idle you had an issue before you did anything.
  4. Likes tux974, tlwjkw, Euroski, W2F a V-King liked this post
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Dave Strong View Post
    I agree with this
    No Mercury should ever have over 18 lbs pressure at WOT you have a spent water blockage leaving the block or a bad gauge ...
    Jayb
    Jay @ JSRE
  7. Likes W2F a V-King liked this post
    May 2001
    Ga
    Sum ting Wong
    Mar 2009
    Hot Springs, AR
    Gauge possibly but I don't think so. 2 4 was clean inside and had no blockage. New 2.0 is clean as well and nothing else has changed.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    Most of the time your blockage or restriction will NOT be in the engine it will be tuner adapter plates ...
    Jay
    Jay @ JSRE
  11. Likes Dave Strong liked this post
    Mar 2009
    Hot Springs, AR
    Adapter plates were clean as could be. I swapped mids and motor mounts at the same time so I got a good look. I had to open the exhaust port in the 2.4 to match the 2.0 but didnt touch anything else. Made sure the gasket matched too before I bolted it together but I'm wondering if there is a difference in water channels
    92 Mirage Ski Racer
    86 Laser LTV Bass
    Quote Originally Posted by dtmeeks View Post
    Might be a difference in dump hole size.
  14. #11
    Mar 2009
    Hot Springs, AR
    It seems that way but it's the same water pump, same water tube, and same 2 peice plate. You would think psi should be closer to where it was. I did go from a 2.4 clamshell cowl to a 2.5 cowl with a pan so I added some height and now wondering if there isn't a good seal on the water tube.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    TX......somewhere?
    did you change tha gasket between tha two plates?.. thats what wrong gasket there will do..
  16. Likes tunnelmike liked this post
    Mar 2009
    Hot Springs, AR
    When I separated it the old one tore so I replaced it. It appeared to match but I'm wonderin if there were maybe some differences in hole sizes I didn't catch. I'm honestly thinking about going to a 1 piece plate and modifying it so I can control the flow.
    92 Mirage Ski Racer
    86 Laser LTV Bass
  18. #14
    ​Bad idea !! IMO ...
    Jay @ JSRE
  19. #15
    Mar 2009
    Hot Springs, AR
    Quote Originally Posted by Jay Smith View Post
    I've seen you say that but I cant figure out why
    92 Mirage Ski Racer
    86 Laser LTV Bass
  1. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  2. Water Pressure/Flow on 94 200 merc...
    By Northerndoc in forum Technical Discussion
    Last Post: 09-19-2013, 07:43 PM
  3. OMC Tech: No water pressure/flow
    By Sum0n3 in forum Technical Discussion
    Last Post: 04-29-2009, 08:34 PM
  4. No water pressure (or flow) on 2.5/260hp EFI (???)
    By Pachanga_rick in forum Technical Discussion
    Last Post: 05-29-2008, 12:01 PM
  5. No water pressure/flow 95 2.5 260efi ?
    By bullet2five in forum Technical Discussion
    Last Post: 07-06-2005, 08:21 AM
