Results 76 to 90 of 169
06-20-2019, 08:56 PM #76USA
1979 Hydrostream Viking with Merc 150, sold in 84’
2014 CheckMate 24' BRX with Merc 400R
2017 TUFF 28 with twin Merc 300XS's
Venezuela
Santos 18’ with 200 Black Max
DaSilva 21’ (Shadow) with Evinrude 300 V8
Whitby 42’ ketch S/V
06-20-2019, 08:58 PM #77
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
06-20-2019, 09:03 PM #78
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,352
- 1069
- 416
- 4748
- 2182
- 9 Post(s)
At least the economy is still buying boats and merc and brp are engineering new products.
Between them they own what percentage of the market you would think they own it with the who ha on product release.
Has yam or suzuki ever had a launch party?
06-20-2019, 09:07 PM #79
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Actually no, the short ex port to ex port distances of travel are more efficient than the long distance run to the end of a can and return to the originating ex port. What's important is the optimal range of arrival in degrees prior to port closing. At slow speeds the arrival is considerably early. As crank rotation speed increases that arrival becomes " later" in respect to port closing. At top rpm it's the optimum range.
The rave permits that arrival to be delayed at low rpm to be near or at optimum range.
That video is without anything except the ex chest and passage from port to port of the original Etec.Last edited by FMP; 06-20-2019 at 09:10 PM.
06-20-2019, 09:30 PM #80
For $64,000 that wonderful new motor should be carbon fiber...
So how much does a 450HP inboard cost?
06-20-2019, 10:26 PM #81
06-20-2019, 10:29 PM #82
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Call me crazy but I'd go 540 XR , twins definitely.
06-20-2019, 10:31 PM #83
Mark
06-20-2019, 11:15 PM #84
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
People will debate the useful interior space with the ob vs io but it's also a matter of clean lines of the hull being disturbed by two or more fatsos hanging off the swim platform. Truthfully wether it goes10+ mph faster with ob I wouldn't care. In that class of boat I still feel big io looks best.
06-20-2019, 11:25 PM #85
I’ll agree with you that today’s engines are more complicated than those of yesteryear,but what powertrain isn’t? Even lawn mowers and weed eaters aren’t exempt.
It’s painfully obvious that all manufacturers except BRP chose to go to 4-stroke when the EPA Phase2 regs came around. I applaud the fact that BRP is sticking to their credo of “emissions can be met with a 2-stroke”, and even went so far as to make 4-stroke owners look stupid by making a 30-second commercial where the 4-stroke owner would get kicked or punched in the nuts every step of the way.
https://youtu.be/nWaqOnXlUhI
Ironically, I’m pretty sure that’s how the guys that bought Fichts felt when OMC closed their doors, but I digress.
If it was so easy to build an emissions compliant 2-stroke above 300 HP, wouldn’t BRP have done it by now? I’ve no skin in the game, only what I read here, but the 300 ETEC and 250 HO ETEC seem to perform basically the same, and neither could keep up with a 300 XS, so it stands to reason they won’t hold a candle to the 300R “car motor” as you refer to it. And they nor Caldwell has shown up with anything with the power, price or warranty. It’s all talk or speculation. Like them or not, at least 400R’s and now 450R’s are real things, not just hype. They’re actually running on boats for the public to view and experience.
If you’ve got a better mousetrap, I suggest you build it so that path gets beaten to your door, and I wish anyone that tries it success. If it is easy, everyone would be doing it. I’m pretty sure it’s not an “all ya gotta do is” situation, or it’d already be done.
I cut my teeth on 2-strokes to start my hi-performance engine career, and enjoyed every bit of it, including building competitive engines for IOGP F1, as well as championship winning snowmobile oval, drag race, speed run and hill climb and water-cross engines, so I have a bit of a leg to stand on. If there’s one thing I can swear by, is that there’s two types of 2-strokes: those that have seized, and those that are going to. It’s really hard to keep something that’s full of holes and huge temperature gradients throughout to keep a round bore, and with that, heat rejection, support and lubrication of the piston. It gets worse with higher specific output. I’m not saying it can’t be done, but it’s going to take a lot of development and precise tolerances, something that’s not conducive to economic volume production.
So I’m going to say everyone that wants that light, hi-output 2-stroke to lobby the sales department at BRP, because they’re the only ones in the game. If you do convince them to green light that, you may want to suggest also investing in a line of gearcases that will handle everything you’re trying to accomplish, because Merc’s the only game in town for that, too. Good luck with all of that. Maybe if you want to gauge interest, you could start your own poll right here on screamandfly.com. Try to have a price figured out what this will all cost and what people will pay, as this needs to be profitable, too.
Until then, would you mind refraining from threadcrapping in threads that don’t interest you? That’d be appreciated.A problem is only a problem when viewed as a problem...
JPEROG thanked for this post
CUDA, powerabout, Brad Zastrow, JPEROG, Robby321, 99fxst99, TooStroked, starviper10, Z06man liked this post
06-20-2019, 11:42 PM #86
All the ballyhoo aside BRP went were the money is, all the **** talk aside if you've ever driven an etec against the four strokes in the working mans engine market....enough said. Merc, Yammy, Zooki, Honder..those motors are about as exciting as paste. But I digress. The Merc 450's? cool as shiz..but about .05% of the scream and fly market will have one....and at 700 lbs the archaic 300 drag will have that ****er for lunch in the drags.
06-20-2019, 11:42 PM #87
5000 RPM
- Mar 2017
- redondo beach, ca
- 128
- 12
- 11
- 39
Why is any one talking about 2 strokes on this 450r thread?i understand you die hard 2 stroke guys will never let it down but its over.. The stock hp wars are over and 4 strokes have won. This a 450hp package on 89 pump gas. add a tune for 91 or better yet e85 and i would expect to see 550-600hp. Note the solid prop shaft for this beast to handle the hp. Yes it is heavier but isnt that because its on the verado mid section? Mercury says this engine is based on the 300r which is the same block (minus cams) as a 200hp v8. So slap on the blower, upgrade the cooling and tune it for 550hp and you might still be under 30k. We just need to get our hands on one of the superchargers to start marking coppies (not exact just for fitment). I doubt we will see any hot 2 strokes left on the water in 10 years other than the rare ones which will be considered classics
HydroSkreamin thanked for this post
06-21-2019, 06:24 AM #88
I couldn’t agree more. It’s going to take people like us to adapt any of the 4-strokes to lighter tubular midsections and put our own electronics on to be able to do cams, compression, bore & stroke, etc..
The alternative is to start developing more aftermarket parts to keep older technology alive. One thing is for sure; people like us usually don’t sit back and watch, so I, for one, am excited to see where the solutions come from for the small go-fasts.A problem is only a problem when viewed as a problem...
JPEROG liked this post
06-21-2019, 06:30 AM #89
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
06-21-2019, 06:34 AM #90
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
Jimmy Wynn and Charlie Strang disagree. They are famous now.
How is investing in the largest die-casting machine in NA something they "needed"? The other manufacturers don't have one; I guess they didn't need it? You're really grasping at straws in your quest against the 4-stroke.
Now that you know about the Sea-Doo Spark, I expect you'll be at the dealership this weekend buying one? They even have the lower hp levels of the old 2-stroke skis you fondly remember!
