Results 1 to 15 of 29
06-13-2019, 11:50 PM #1
$400 and 6 Months Wasted! Picked Up My Re-Sleeved Merc 2.0 Today And Was Shocked
Guys, after waiting for 2 different shops for 6 months and a "special order" LA Sleeve (had to be made super thick), I finally got the call to pick-up my long awaited Merc 2.0L fatblock project block with what was supposed to be a new, sleeved #6 hole.
How does a long running and locally touted shop get by with this kind of product? Now my project is delayed again while I order a special sleeve and find a new shop. I won't be bolting this together.......Gordon
06-14-2019, 12:07 AM #2
Looks about like the xr4 fat block I had years ago. I pulled the heads off and WTF straight from merc it looked just like that. It ran well enough for a ski boat but yeah...
06-14-2019, 05:43 AM #3
Supporting Vendor
- 11,838
- 163
- 11
- 797
I use Dwayne Roberie in La. he does my sleeving and bore work on steel and nickel been real pleased and great to work with ...
JayJay @ JSRE
06-14-2019, 06:15 AM #4
So how thick is the sleeve?
06-14-2019, 07:30 AM #5
A #6 rod made a mess of the original bore so it needed a thicker sleeve. They don't stock these..... Part # L-04-OB +40 with OD = 3.418"
gmjim thanked for this post
06-14-2019, 08:43 AM #6
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
I know fat block 2.0's aren't the most common but I buy old 150's running for $400 and less regularly. Even bought a 175 EFI in pretty good shape for $400. Maybe just find another block?
Josh Peterson
sonicss33 liked this post
06-14-2019, 11:10 AM #7
Why not put it in oven and then properly index sleeve? Unless of course I am missing something else.
RockTeam Junk
06-14-2019, 05:07 PM #8
Rock, according to the sleeve guy, the block should have been heated (expanded) and the sleeve left room temperature or less and then pressed in-place with an interference fit (aligned of course). If installed correctly, heating the block with the sleeve in-place as running does, the sleeve expands and will not come out or rotate without some block damage. He recommended boring the sleeve out only and fitting the new/replacement correctly. I have a new, custom make sleeve ordered and should have it before I find a new shop to trust doing the work. Gordon
06-14-2019, 05:15 PM #9
I would run the thing before investing another penny in an obsolete block. There is no point in spending another penny. I wish I had pictures of that old xr4. Every sleeve looked like yours and that was untouched from the factory.
06-14-2019, 05:17 PM #10
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
Fat block? ya mean 2.5 based 2.0? so they are worth something?
06-14-2019, 05:19 PM #11
The sleeve was made with larger ports than what the block was cast with. The first couple years of the fat block that weren't 2.5's were sketchy as hell.
06-14-2019, 05:20 PM #12
06-14-2019, 06:39 PM #13
I have never even heard of someone trying to sleeve a block without heat. If sleeve is installed without heat how is it installed or should I say secured? I put three in a 90 Merc the other day and screwed one of them up. Not as bad as yours but still it was wrong. Back in the oven and rotated it a bit and good to go. Unless sleeve is cast in place I cannot imagine it not coming loose with heat.
RockTeam Junk
keefallan liked this post
06-14-2019, 11:18 PM #14
Guys, the "why" is not what you'd expect. I do this to keep me busy and enjoyment. I need this 2.0L like another hole in my head - in fact, I don't even have a boat for it yet. I've got 2 vintage Chrysler outboard restorations in-process too. I am a busy-body as my friends say. I can't sit still, don't watch TV, and love working with my hands. I like this block because it was free.....I took it's power trim off for the previous owner and installed that into his Skeeter/XR4 and got the complete 135 SeaRay outboard for my trouble. I realized on teardown that is has very few hours and I was going to make it good again. 5 of the cylinders still have the cross-hatching on them. It died an early death because of #6 seizing when the water pump impeller failed. I found pieces of rubber impeller everywhere. So it's not the cost, not the timing - I wanted something to do.
I love collecting and enjoy restoring. My garage got full and the wife said I had to find a new hobby.....Gordon
Right next to the Allison....
powerabout liked this post
06-14-2019, 11:34 PM #15
tha XR4 merc sleeve's were like that from tha get go ('87 up)…. their first attempt atta steel 2.4..
I saw something today that shocked me. Really.
By Scream And Fly in forum The Scream And Fly LoungeReplies: 18Last Post: 08-25-2016, 07:27 AM -
Picked up TWO Vipers Today
By wireless in forum General Boating DiscussionReplies: 36Last Post: 07-13-2010, 06:39 PM -
Venom Picked up today!
By Stream 1 in forum General Boating DiscussionReplies: 57Last Post: 12-25-2005, 10:36 AM -
Picked up 700 RPM's today !
By BOUDREAUX in forum Technical DiscussionReplies: 2Last Post: 12-02-2003, 09:57 PM -
Picked up a 1986 3.4 300 today!
By Vicious One in forum General Boating DiscussionReplies: 14Last Post: 09-17-2003, 05:05 PM
