Results 1 to 15 of 18
    Mar 2009
    Hot Springs, AR
    Got her too hot.
    I've got a chrome bore 2.4 200 that got hot on me. It's down on compression in 2 holes so I pulled the head and found where the piston was dragging. It doesn't look scared and the rings didn't get into the ports so I'm wondering what route to go?
ID:	441694Click image for larger version.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    82 Hydrostream Vandal Comp
    ^(project that needs a new home)
    Pekin, IL
    First I would get some muriatic acid and very carefully remove aluminum build up in cylinder in order to see the true condition of the cylinder wall.
    Rock
    Team Junk
    Mar 2009
    Hot Springs, AR
    Thanks. A guy up the road said the same thing this morning. Gonna try that then probably throw a piston and rings in it if it's not too far out of round.
    92 Mirage Ski Racer
    86 Laser LTV Bass
    Baton Rouge, La
    I'd run a ball hone thru it after. Sometimes a wire brush helps. Stuff rags in the cylinder and try to have the motor trimmed slightly down to keep the liquid from running twords the crank. Mike.
    Cheaters never Win !!!
    Jun 2009
    central minnesota
    how bout the crack in the ex port?alum off the piston skirt built up and then got HAMMERED by the rest of the piston and pushed out the wall. oooorrrr maybe im just seeing things -th
    Mar 2009
    Hot Springs, AR
    Mike, I dont know this but I was under the the impression that you couldn't hone a chrome bore. I'm not opposed to trying if there is a chance it won't strip it off
    92 Mirage Ski Racer
    86 Laser LTV Bass
    Mar 2009
    Hot Springs, AR
    Quote Originally Posted by mn808gade View Post
    It looks like a crack from the picture but it's actually a little rigde that I'm assuming was in the casting
    92 Mirage Ski Racer
    86 Laser LTV Bass
    minocqua, wis
    stuff the hole as tight as you can ,with plastic bags keep Muratic acid away from crankshaft journals it will destroy them
    Pekin, IL
    You must keep the acid AND the acid's fumes away from anything steel as it will ruin it.
    Rock
    Team Junk
  10. Likes keefallan liked this post
  11. #10
    Mar 2009
    Hot Springs, AR
    Will do, thanks. Any recommendations on rings and gaps for the new piston?
    92 Mirage Ski Racer
    86 Laser LTV Bass
  12. #11
    TX......somewhere?
    think ya would be ahead if ya went ahead and took it completely down ta use tha acid and any kinda hone on it.. won't take but one wayward little drop ta do tha crank and/or bearings in.. it really needs ta be washed good anytime ya haft ta remove anything metal anyway... jmo.
  13. Likes rock liked this post
  14. #12
    Sep 2017
    Ashland city tn
    I've took a cotton swab and dip tip of it in muriatic and try clean like that, keeps from dripping and much. But put sumthin n cyl in case of a drip ,, I had one do that but not as bad but still didnt clean up like I wanted. I've heard u cant hone a chome cyl but I've heard u can hone one but its gotta be certain hone also to achieve slickest finish possible
  15. Likes dtmeeks, keefallan liked this post
  16. #13
    Baton Rouge, La
    My bad ! The 2.4 I raced had been sleeved due to the bored bieng out of round. The rest of the process works. We would pull the piston out with the motor assembled.
    Don't drown the hole with acid. I would put it on a wire brush and rub the aluminum off the cylinder. It's not a difficult process. Mike
  17. #14
    Mar 2009
    Hot Springs, AR
    I'm gonna see how far out of round it is first and that will probably determine the route I take. What is an accepted tolerance if its not perfectly round?
    92 Mirage Ski Racer
    86 Laser LTV Bass
  18. #15
    Baton Rouge, La
    It doesn't take too much out of round to be a problem. Round rings don't seal well in oblong bores. If you have a good piston to replace the burnt one you can reassemble it and check the compression. You can even check it with the old head gasket if funds are tight. If it's close to the others I'd run it. You can get to the rod bolts with the intake removed.
    There are 2 nice 2.4 drop on's for sale in High Performance Boating page I think is where I saw them.
    I think it would be worth it to replace it instead of spending money resleeving if it comes to that. Mike
