Results 31 to 45 of 56
Thread: Tygon!
05-28-2019, 02:32 PM #31
05-28-2019, 06:30 PM #32
5000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
If your not going to Napa, call first to be sure ethanol compatible fuel line in your size(s) is in stock. I went to FOUR local auto part stores in the Cincinnati area (advance, auto zone, k.o.I., O'Reilly's) only to be told unavailable or special order!!!!! BUMMER!!!!!
Spoiled for years having Napa around the corner. Was very disappointed in not being able to finish up a carb and fuel pump rebuild with fresh fuel lines from local store same day.
Couldn't believe with all today's pump gas having ethanol, these stores would carry anything but ethanol rated fuel line!
Merc 2.5 liked this post
05-29-2019, 09:08 AM #33
Local Stihl dealer always has lots of good fuel line product. Aeroquip if you want to go one and done
90 5.0 liked this post
05-29-2019, 09:12 AM #34
I have an account @ U.S.Plastics / Tamco, where I buy push-lok tubing and fittings. (Yes they probably even mfg the tygon that McMaster sells ,
) for air brake , other pneumatic and water transport. Each has their perspective range of applications.
The reason I mentioned NAPA and specifically the EFI hose is because in it's list of applications it says it can be run "submerged" . I already posted a picture of it tied in a knot ... So we know it's pliable .. reliable and if your not stuck in yesterday ... desirable ...
Not bad, 3 pages over ................ 1/8" hose ....
Next week we'll cover "new age" two layer hyd hose with crimped stainless ends..
Advance .. I have an account there too. OK , clip a corner off my man card I deserve it .. LOL The junk they sell is not meant for you or I unless you need a quickie fix on the side of the road to get you home. They tell you if your going to run it submerged then they will give you a Dayco part # . Which I'll bet is a EFI type hose ...
https://shop.advanceautoparts.com/p/...986%7CL3*15373
mach351 liked this post
05-29-2019, 12:45 PM #35
I’ll one up that hyd hose Chaz.....I made mine with those stainless ends, but used 4000psi nylon braided bonded hose used for forklift masts.....sweeeeet
or I guess I could use tygon
'95 STV "The Blue Goose"
05-29-2019, 06:10 PM #36
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Not sure if tygon is butyl ether safe. It pops up in non alcohol fuel every once in a whhile. Even the good Napa stuff won’t last if you supply of fuel has it because the distribution center brought in the only other road fuel that meets epa oxygenated gas besides methanol and ethanol.
Nothing like gummed up tanks and vst full of butyl rubber droppings when it phase separates.'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
05-29-2019, 06:47 PM #37
05-30-2019, 10:35 AM #38
05-30-2019, 04:45 PM #39
5000 RPM
- Feb 2009
- 419
- 62
- 28
- 136
- 162
So that's what's eating up ethanol resistant fuel lines? Seen the Melted looking blobs stuck to the bottom of carb bowls and thought WTF!?! after replacing all fuel lines, fuel filters, and rebuilding fuel pump, and cleaning the carbs.
Is the fuel line with the liner inside impervious to this butyl ether?
Need to start a thread on this, to enlighten a few more folks!
05-30-2019, 10:44 PM #40
You'll need to put them in a time machine and take them back before the turn of the century when it was legal for refineries to blend MTBE Methyl tert-butyl ether in gasoline as a lead substitute.
And ... LOL ... no it didn't eat fuel line, but it was he11 on our fresh water. Mostly from old leaking underground tanks.
Wanna know what eats alky resistant fuel line ... ??? CHEAP AZZ " RESISTANT " fuel line ...
It's kinda like wrist watch's ..
You can go to the mens jewlery counter at Wal-Mart and get you a nice water resistant watch for $29.95
I'll take ya spear fishin off the reef outside the inlet . I'd give it to about 8 to 10 feet before it marked your first trip to the bottom ...
Speakin of quality ... Mach 351 , I'll see your Gucci forklift hose. and raise ya ..
This is the high class - Grey poop-on model ..
Straight stainless fitting $ 73.95
90* stainless fitting $ 107.49
tygon hose .27 c
05-30-2019, 11:36 PM #41
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Your thinking Tetra Ethel Lead Chaz
much like ethanol becomes famalgahide which becomes acidic acid
propyl alcohol / iso propanol / 2-propanol converts to acetone normally not an issue, but eats plastic like butyl Ether eats rubber. Only some though. Theirs a chart for reactivity somewhere.
Mtbe came around in the ninety’s and literally ruined every car on the road and every outboard that didn’t get updated like the y2k bug. And the reason you see so much grey silicone fuel line. Canada banned it. It’s also why tanks are above ground at gas stations. Ground water contamination. Ethanol bills have made it all but disappear. Will poke it’s head randomly. We got it here in Missouri during the gas price crunch/ gas relief act that stoped mandates on ethanol and stations could get whatever was cheapest.
Worst to me is when they put the alcohol back in when they get good clean gas, by adding heat which is a pinte of pure methanol. Cupple stations were doing that here think I got them stopped unless they test positive for water. Probably not.
05-30-2019, 11:41 PM #42
05-31-2019, 09:04 AM #43
No sir , no confusion here.
Tetraethyllead is the lead in leaded fuels. It can still be sold in racing fuels, AVgas, etc. but not for highway use.
As I stated MTBE was used as a TEL replacement , then why and when it was replaced. No need in repeating my words.
Try to buy 5 or 55 gallons of it .. let me know how that works out ..
Problems arose when Ethanol was used to replace MTBE, not before.
There's no need in dancing around all the iso,propanol,ethyl, methyl,hydroxyl groups ... just call it wood or corn. I'll know what your tryin to say
05-31-2019, 11:07 PM #44
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Heh 5-55 is easy. start! Brand fuel additive That stuff bill dance did commercials fore is pure mtbe little bottles of it in Wally World, and the occasional random gas station. Not sure you can buy a gallon but you can clean them out of the little bottles.
Guess i I never thought when mtbe actually started, till the epa mandate came around for oxygenated fuel.
06-02-2019, 07:37 AM #45
Tygon Oil Lines
By bouyhead in forum General Boating DiscussionReplies: 5Last Post: 04-10-2018, 11:21 AM -
Tygon Tubing
By laglass69 in forum Technical DiscussionReplies: 23Last Post: 01-27-2011, 12:01 PM -
Tygon Tubing FYI
By Ranger976 in forum Technical DiscussionReplies: 14Last Post: 05-09-2008, 03:27 PM -
Tygon Tubing
By bucket in forum Technical DiscussionReplies: 12Last Post: 04-08-2003, 11:25 AM
