Page 11 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 151 to 165 of 215
  1. #151
    Oct 2017
    Hugo, MN
    TwzteD, what an AMAZING build.
    Unreal.
  2. Thanks TwzteD thanked for this post
    Likes TwzteD, noli, LakeFever liked this post
  3. #152
    Mar 2009
    Saint Lucie Florida
    Mar 2009
    Saint Lucie Florida
    BTW, my cap was paper thin, trying to save weight, i cleaned it up and didnt add a fresh layer of glass to it, i put core right down on the old stuff, glassed over it. after it was cured i put it back on the boat, my 225 lb buddy stood on it and bounced a few times, didnt even move or make any noise and it wasnt even glued or tabbed in, and i didnt even have gussets in at that point, pretty strong stuff, i glued it all in with bedding compound, spread it with a fine tooth trowl and squished the excess out by starting in the middle with a rib roller.
  5. Likes noli liked this post
  6. #154
    beautiful!
    who built your interior cushions?
  7. #155
    Mar 2009
    Saint Lucie Florida
    Mar 2009
    Saint Lucie Florida
  9. Likes noli liked this post
  10. #157
    Mar 2009
    Port Saint Lucie
    Nice pics.
  11. Likes TwzteD liked this post
  12. #158
    Used the 1/2'' HS-80 divinny cell on my V-King years ago. No problems. It will be louder (hull noise) when going over small chop and ripples. Penske core board 12# density, 1/2'' for floor and 26# 3/4'' for transom. 3'' thick overall on trans. No problems....I have run 505# optimax and EFI 3.0 mercs and have jumped the boat many,many times.
  13. Likes nitro_rat, TwzteD, noli liked this post
  14. #159
    Jun 2018
    Floating around
    TwzteD wow that builds looks bomb proof. Very impressive, do you have a build thread somewhere?
    Hippe thats pretty much what I was thinking. If the original lasted 30 years, my recore with balsa should last at least the same. The idea of rot proof core sure sounds appealing though
  15. Likes TwzteD liked this post
  16. #160
    Mar 2009
    Saint Lucie Florida
    Jun 2018
    Floating around
    Wow, extensive and impressive. I will be reading every page of that thread soon
  18. Likes TwzteD liked this post
  19. #162
    Mar 2009
    Port Saint Lucie
    Its a good read.
  20. #163
    the flooring, which has exposed wood is soft and deteriorated
    not sure if this was done by previous owner or came like the from factory?
  21. #164
  22. #165
    Hello my wetness, didn't expect to see you so spoon!
    I removed the skin covering the balsa core in the pad area, all wet, soaking wet
    first I used the circular saw just to score the skin, then completed the cut with that tool
