Results 16 to 30 of 41
    Feb 2017
    Wixom lake michigan
    Looks like a big project, but should be a cool boat when done. Wonder why someone would paint over red .metalflake? More than likely you will have more into it than its worth, but as said before, do it right and have a nice bowrider for years and years. Is that a 25" mota??
  2. #17
    Jan 2015
    Quote Originally Posted by Mhall222 View Post
    Yes the bracket itself was full of water. I did find a broke off plastic plug in the bottom so I drained it and now I have plenty of tongue weight.
    After seeing some of the additional pictures you added, you mean the motor mount bracket was full of water?
    That would be a lot of weight. Probably coming in from the top, rather then the bottom, right?
    Rough idle could be a few things. On something that old, I would replace the reeds. If you are going to pull the carbs, you are half way to the reeds.
  3. #18
    Jan 2015
    https://www.wholesalemarine.com/john...-6-looper.html
    Those CDI coil packs are for 86-87
  4. #19
    Was thinking 26 maybe 27"
  5. #20
    Jun 2009
    Leesburg, GA
    Oh man, Anyone want to give me $3000 for this project? I have a little more in it at this point but I think I would let it go for that or otherwise I better get to rebuilding it or part it all out.. I figured the trailer is worth $1000, Bracket $500, Motor $750, and Hull with title $750.... Really the only thing this boat "needs" is the floor, stringers, and core repaired as well as fixing some of the seat bases and upholstery panels with new plywood. All the rigging, wiring and fuel system are all pretty nice and in great shape. All the fittings on the boat are nice and I do not see anything that really needs to be replaced besides repairs to the stringers,floor, and core.. I know I know...... Good luck to me on selling this project If anyone is interested I may even consider trades of various types..
    1998 BackCountry 201 Proguide, 250xs
  6. #21
    You cannot do all the rest and not the transom, you just can't. She'd be sweet all light and solid!
  7. #22
    Jan 2015
    For the low low cost of $19.95 you too could own this project......
    But wait........It gets better.........
    The guy I bought it from says it only needs this...........and maybe some of that.......
    It is not bad enough I got screwed. I am going to try to pass it along.
  8. #23
    Jun 2009
    Leesburg, GA
    Quote Originally Posted by SS Minnow View Post
    Oh come on now, You know this project is worth more than $19.95
    I am just going to jump on this and knock it out. I honestly do not mind such an in depth project but dangit, I hate itching all night long. hahaha I have 7 gallons of epoxy and lots of other building materials on hand that I might as well use now. I hate to say it but I bet every one of these Concords that spent any time outside uncovered has the very same issues this one has. There was water soaked up in every cubic inch of foam and although some of the balsa core is good a lot of it is not. It looks like the balsa really soaked up a ton of resin as some of it is rock hard and I can not scrap off. I hope this is not the case for all the core on the bottom of this hull. I am not positive but It sure looks like the stringers were placed on top of the core or maybe they just ran the glass from the core up and over the stringers..Anyhow, I Need to dismount the motor/bracket and I guess get this hull sitting on a good set of bunks before I cut the core and stringers out.
    Does anyone have any idea if these boats had some obvious hook int he hull? I would assume it does or maybe the weak stringers are allowing the hull to flex up a little more than it should be? I can not find any pictures or info on if these boats had built in hook or not.
  9. Likes FMP liked this post
  10. #24
  11. #25
    Jun 2009
    Leesburg, GA
    Thanks, I have exhausted google search looking for more info on these boats and even google is coming up short.
  12. #26
    More links within those links. Brian and Fritz are the builders, and quality from what's been mentioned.
  13. #27
    Dec 2006
    Central Wisconsin
    Brian has recently passed away so info is hard to come by. The web site has been down for over a year. There is a Concord owner's group on Facebook. My mach II hull does not have a hook. My cousin had a 22 magnum and the bottom blew off at 40mph due to a rotten core. That boat would run 80 also and he's lucky he wasn't running at speed when it came apart. He's jeepster21 on here, not active member, but posted some pictures.
  14. #28
    Jun 2009
    Leesburg, GA
    I was in the process of stripped this hull down so I can haul it to the local landfill. After removing the windshield I stepped back and had the most horrible idea come to mind. I thought "this would sure be a sweet looking center console boat" Anyhow, I then went inside to call the landfill to get an idea of how much it is going to cost me to drop this hull off. Looks like $80 per ton and they would be glad to pull the boat off the trailer for me. I guess I could load it up with some other junk around my property that need to go to the dump and just get this boat out of my sight or I can put it over in the corner of the yard and maybe build it into a center console someday. The biggest issue with building it into a center console would be that the floor would have to be build pretty high if I made it self bailing otherwise water would constantly be coming in through the drains. I guess I could move some weight forward to get the boat to sit a bit more level but then it would never be as fast. Anyhow, That was my horrible Idea that i need someone to shoot down so I can get this thing dropped off at the dump.
  15. #29
    I can't stand it when a restorable boat goes down the road. For what you have in it wrap it up and make it next winters project. You can only crush it once and then it's gone. Nice looking bow rider.
  16. #30
    Massapequa NY
    that would be a nice looking center console!
  1. '92 200xri on Concord Mach II Set-up Questions
    By Hess in forum Props, Setup, and Rigging
    Last Post: 05-18-2015, 08:04 PM
  2. 88 concord mach II 200 blax max merc
    By concord 1 in forum General Boating Discussion
    Last Post: 03-10-2013, 08:59 PM
  3. Concord Mach II Questions
    By Mo Power in forum General Boating Discussion
    Last Post: 02-11-2012, 01:49 PM
  4. Any Other Concord Owners On Here??
    By 87MagnumII in forum General Boating Discussion
    Last Post: 06-02-2011, 11:49 AM
  5. 1992 concord mach ii
    By goznya in forum General Boating Discussion
    Last Post: 06-15-2009, 09:44 PM
