Results 1 to 10 of 10
Thread: Torq-flo safety issue
04-19-2019, 07:52 PM #1
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,963
- 600
- 100
- 524
- 633
HAS anyone had any issues with hi speed surfacing apps, prop wobble, cracking? dont feel the insert is up to the task, i can rock the prop alittle too much, right before the nut tightens. i know the prop is against trust washer so why do i have side to side play, the nut cant control side to side thrust. only fore and aft movement. question; should tightening the nut, squeeze on the plastic, forcing it deeper into hub, or should a tap in be enough? turning a 26p running 78, small shaft dont want any surprises. comments welcome, thanks
04-19-2019, 08:17 PM #2
Supporting Member
- Jul 2004
- Connecticut
- 6,253
- 520
- 210
- 1078
- 1133
If you are surfacing there is a different Flo-Torq hub insert that should be used.
04-19-2019, 08:21 PM #3
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,963
- 600
- 100
- 524
- 633
is that a torq-flo ll solid hub?
04-19-2019, 08:21 PM #4
Supporting Member
- Jul 2004
- Connecticut
- 6,253
- 520
- 210
- 1078
- 1133
04-19-2019, 09:01 PM #5
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,963
- 600
- 100
- 524
- 633
thanks r surfacing apps, trophy, tempest, bravo says new from mercury ! best part 29.00 $ ebay. what a deal. there are a lot of choices, i ordered it. the mor hubs are for 1.25 shafts fyi 835257k6 surfacing, small shaft.
04-19-2019, 10:29 PM #6
6000 RPM
- Feb 2014
- Missouri
- 1,211
- 66
- 12
- 83
You should have a castle washer or brass tube splined to the shaft the with a finger lock washer to lock the nut.
Yes the inner lip or step in the thrust washer should mate perfectly to the inner tube of the hub the sacrifice piece slides into. It controls endplay. The castle washer or splined insert control the other end.
Theirs also a full length brass that contacted the thrust washer but used with the wrong props allows them to slide up and down the shaft.
I didnt think ft 1 was available anymore. 2 is sutible just noisy to some people. 3 and 4 are the same just different hp
3-4 sound horrible on the surface.
04-20-2019, 12:05 PM #7
To run surfacing props like Trophy 835257K6 is the hub kit you want. It has a stepped plastic cone that goes between the thrust washer and plastic hub insert to help support the prop. The torque is 75lb/ft vs 55lb/ft.
04-20-2019, 07:55 PM #8
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,963
- 600
- 100
- 524
- 633
DAVE, I DID ORDER the correct one after all! 835257k6 saw it for 2x what i paid. says 100 ft lbs!
Dave Strong liked this post
04-20-2019, 08:17 PM #9
04-21-2019, 10:04 AM #10
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,963
- 600
- 100
- 524
- 633
Flo - Torq hub
By Chaz in forum Technical DiscussionReplies: 7Last Post: 12-28-2016, 01:37 PM -
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
Need help, Flo-torq hub...
By lokinutz in forum Technical DiscussionReplies: 3Last Post: 01-12-2007, 02:04 PM
