Results 31 to 45 of 53
  1. #31
    For that application I would have used grade 8 bolts in metric size to make it the tightest fit I could. The holes in the bracket are 9/16'' and using grade 5 SS 1/2'' bolts is not good enough. And brass nuts are way too soft.
    Nov 2003
    Portsmouth VA
    At about 30 minutes when he says and we’ll work on it tomorrow that says game over to me. The internals in that engine will cook overnight.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  3. #33
    NE Louisiana
    You ever seen grade 8 in a salt environment? They are bad enough when they are not, plated or not.
    They make different grades of SS. I think they should be using at least 5/8 fine thread, or two 1/2 top bolts each side as said, six bolts per motor. Mine has 8 on each motor.
  4. #34
    Aug 2006
    virginia
    [I]not that hard to bolt an engine up...double everything
  5. Likes Forkin' Crazy liked this post
  6. #35
    NE Louisiana
    Torque wrench, locking stainless nuts, red locktite for good measure. If seriously in doubt, aircraft safety wire. I use torque wrench on everything these days it has upped my end game of builds ten fold. Hardly ever have mystery fails anymore. Who'd a thunk it, until ya sunk it
    You like using cut off wheels? Or just like torture? SS nylocks are bad enough.
  7. Likes RSWORDS liked this post
  8. #36
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by flabum1017 View Post
    Merc would ask to see the pieces still bolted to the boat.....
    With Some of the insurance battles I've seen.... they would want the motor if possible.
  9. #37
    You have to eliminate movement with the slamming those motors are getting. They make grade 8 metric bolts in SS.
    NE Louisiana
    What is a source? Fastenal has nothing.
  11. #39
    These guys have them.
    https://www.bumax-fasteners.com/
    NE Louisiana
    How much is that??? LOL!!! And who uses it in boat rigging??? Surprised it wasn't aerospace!!!
    I am not an engineer. Who can translate this?
    https://www.bumax-fasteners.com/prod...olt-and-screw/
  13. #41
    They are used in lots of applications and have dist. in the US. If you want the good stuff, you can't get them at ace hardware....
  14. Likes Rigaud liked this post
  15. #42
    NE Louisiana
    Okay. I'll venture a guess.. you don't know.. Last I checked Fastenal wasn't Ace.... SMH...
  16. #43
    PARADISE /Naples
    So Fastenal said they can't get you a better grade? I thought the Merc ones were good? Don't believe this was the bolts fault here, negligence.
  17. #44
    I was kidding about ace. Fastenall has the stuff everyone uses. These are specialty bolts. But anyway, stainless hi-grade bolts do exist.
    Jun 2018
    Floating around
    321 alloy bolts iirc are the good ones to use. Low gall, high strength. I believe there is also 410 or something like that but not as corrosion resistant.
    Red locktite lol, yeah need some heat to crack loose. Same with nylocs a bit of heat helps a LOT but one time use. There are those distorted nut lock nuts as well as the sliced/pinched ones. All one time use with stainless imo due to the thread galling BS
  1. always thought this rig looked like a contender,
    By mr fun in forum General Boating Discussion
    Last Post: 07-26-2017, 07:26 PM
  2. Anyone in Chipley, FL ? Need an engine looked at
    By Stoker1 in forum General Boating Discussion
    Last Post: 08-04-2013, 10:59 AM
  3. My workbench has never looked so good
    By rock in forum General Boating Discussion
    Last Post: 05-31-2011, 01:06 PM
