Results 301 to 315 of 496
Thread: 13' Bullet 130 Rebuild & Repower
02-12-2019, 07:09 AM #301
The cap still needs to come off so we taped it up so the resin wouldn't stick to the transom, we used foam to wedge between the splashwell and transom to shape it so water will drain into the middle. I have to take the cap off to cut the old splash well off and glass it from the bottom and drill the holes in the knees for water to drain and a hole in the transom for water to escape., I also have to add some wire guides for all the cables and install the gussets. I will still be flipping the boat over again to finish fairing it and prime it then the cap will get glassed on permanently, at that time the back will be glasses to the transom and knees etc. All that is a lot easier with the cap off so it will be permanently glued then glassed after all that is done.
02-12-2019, 08:00 PM #302
02-12-2019, 09:23 PM #303
7000 RPM
- Mar 2009
- Port Saint Lucie
- 2,530
- 31
- 256
Couple pics. Freshly cleaned up and rinsed off. The bottom still needs glass. But we're adding coosa plugs where the bolts will be. So it'll get finished when the mounts are figured out.
02-12-2019, 09:33 PM #304
Who made the fuel tank for you? I like the cylinder type for my project.
02-12-2019, 09:41 PM #305
Bam manufacturing, they do custom tanks also like mine, I added top pickup, baffle and
A 1/4 vent in the fill neck
https://www.spunaluminumgastanks.com
W2F a V-King thanked for this post
02-13-2019, 10:38 AM #306
Screaming And Flying!
- 15,068
- 407
- 1453
- 6036
- 11679
What's the blue fairing material on the deck?
02-13-2019, 12:27 PM #307
Member
- Mar 2018
- Laval, Quebec, Canada
- 43
- 234
- 24
Hot hot hot
02-13-2019, 02:18 PM #308
02-13-2019, 02:20 PM #309
02-13-2019, 02:44 PM #310
- 15,068
- 407
- 1453
- 6036
- 11679
That's what I thought it was.
TwzteD liked this post
02-17-2019, 08:38 PM #311
02-18-2019, 04:39 PM #312
02-18-2019, 07:01 PM #313
02-18-2019, 07:13 PM #314
7000 RPM
- Mar 2009
- Port Saint Lucie
- 2,530
- 31
- 256
02-19-2019, 09:43 PM #315
What’s the point of the gusset pads if you don’t mind me asking
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
Evinrude XP200 Rebuild or Repower
By Stoker88 in forum Props, Setup, and RiggingReplies: 6Last Post: 09-09-2020, 11:06 PM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
30' velocity rebuild/repower/reeverything
By biohzrd in forum General Boating DiscussionReplies: 66Last Post: 08-03-2010, 10:39 AM -
Repower advice: OptiMax or rebuild 2.5EFI
By mercfan1 in forum General Boating DiscussionReplies: 8Last Post: 11-11-2008, 09:02 PM
