Results 1 to 15 of 34
02-09-2019, 09:08 PM #1
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Help Identifying a Mercury I bought
I bought this motor and was told it was a 2.5 200 carb motor. I can't find the serial number for the motor.
Build Stamp is 4-28-94
I can't tell if the block stamp there says AA or AA with an F there, not too sure really. Just trying to figure out what I have.
Any tips on what to look at? It is sitting on a different mid so that's of no help either. Want to know if it is worth rebuilding.
02-09-2019, 11:30 PM #2
should be a welch plug on top with a serial number
02-10-2019, 03:44 AM #3
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Unfortunately it must’ve been replaced at one point. Nothing on the Welch plug
02-10-2019, 06:32 AM #4
If it were mine, I'd pull a head and measure the ports....If your gonna build it, it's coming apart anyway.
02-10-2019, 08:21 AM #5
Ya seems to me u have a merc replacement block and ole mother merc didnt always stamp em , can u post a pic of the block?
02-10-2019, 09:48 AM #6
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
I’ll get some pictures of the block. It could be a replacement block. I’ll measure the port height as well
02-11-2019, 12:27 PM #7
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Took a few more pictures of the block and other parts.
02-11-2019, 12:44 PM #8
Block sure looks like 2.5 to me
O and next guess is #1 went lean from carb or lectrics
What's the measurement across cyl?3.5?Last edited by Merc 2.5; 02-11-2019 at 12:49 PM.
02-11-2019, 12:47 PM #9
And that aaf on block little weird to, usually just 2 letter
02-11-2019, 12:53 PM #10
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
I was hoping it was an FF block. You can see where it said FF, The First F is barely visible under the first A, but then it looks like someone went over it with the AA which is interesting.
And Cylinder #1 definitely looks like it went lean.
02-11-2019, 01:25 PM #11
If it went to merc they mite had put the aa sleeves in it or sumthin , would cause for the stamp but idk, did u measure piston?
02-11-2019, 01:27 PM #12
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
02-11-2019, 02:47 PM #13
They mark blocks. Ff, aa etc, guess it's the sleeve in blocks that are different
02-11-2019, 03:07 PM #14
rotate and see if the exhaust port has relief notch in it
02-11-2019, 03:42 PM #15
That is going to be a 2.0L 150. Bores look to be smaller than 3.500"
WMH-31 are 150 carbs.
W2F a V-King liked this post
Help with identifying a Mercury powerhead.
By Rob'Z in forum Technical DiscussionReplies: 27Last Post: 03-11-2022, 07:33 PM -
Bought my first fast boat today, action 18 need efi identifying help?
By tompearson in forum General Boating DiscussionReplies: 20Last Post: 07-25-2015, 06:38 PM -
Mercury Tech: Help identifying Mercury
By riverrat321 in forum Technical DiscussionReplies: 3Last Post: 10-15-2012, 08:58 PM -
OMC Tech: bought pig in poke lower unit need help identifying
By rebible in forum Technical DiscussionReplies: 3Last Post: 08-24-2012, 11:20 AM -
Identifying Mercury V6s
By AxisMoto in forum Technical DiscussionReplies: 3Last Post: 06-06-2005, 08:27 PM
