Results 46 to 60 of 60
Thread: 24 skater what motors
02-02-2019, 01:06 PM #46
baja1000 liked this post
02-02-2019, 01:16 PM #47
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
02-02-2019, 01:23 PM #48
02-02-2019, 01:54 PM #49
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
For one reason or another, my boat hopped with twins and hops with a single. The hop speed changed some; now it’s 65-75. It will hop 5-10 times at wot while passing through. I found a 0.100” hook over the last 6” of pod that may have contributed, but I’m removing it now.
02-02-2019, 04:52 PM #50
Any air entrapment hull will have a spot iwhere it switches from hyd lift to air. A 10mph hop window is tunnel boat problems that’s great. my 500lb tunnel has a 15mph window if you try to cruise there but Again 24 Skater different animal. We have set up a couple real cats and it’s different.
02-02-2019, 06:34 PM #51
My 23 Daytona had no hop the last 2 feet of hook removed. I would not like it with a single motor unless it was Least 500 hp and 700 pounds
02-08-2019, 09:50 PM #521) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
02-08-2019, 11:18 PM #53
I am currently rigging my 24 Skater with twin 250 Optis, 300X Mids, 1.62 Sportys and Dewald props. I have moved the batteries to the forward bulkhead, eliminated the secondary boost pumps and mounting the motors directly to the transom instead of going with 15" mids and jackplates. By the time I lost the Opti weight with the 15" mids, I was adding it back with the jackplates.
There is simply no comparison to the fuel economy with the Optis and these boats ran 110+ with old school Carb'd 200hp mercs and 3-blade cleavers. With today's prop technology, lightweight batteries and canbus rigging, I can remove unnecessary weight with ease. Now if I could only build a carbon reinforced aluminum tie-bar... I could remove another 20# from aft of the motors!!
I will also look into running Carbon motor cowls to reduce the weight and replace the metal trim pump systems with later Volvo systems which have a greater pressure/flow with lighter composite body.
02-09-2019, 06:59 AM #54
02-09-2019, 08:17 AM #55
We rigged a buddies 24 with twin 15” 250 Etec 1.62 sportys. We put the batteries in front of the bulkhead and it was better. it ran 109 on limiters needed more prop. Got on plane like a Jetski and easily powered through the hop full of fuel and 4 people.
02-12-2019, 04:44 PM #56
02-12-2019, 05:10 PM #57
02-13-2019, 08:18 AM #58
300xs hours
0 to what is new
New to good
Good to old
Rebuild
Willow Valley AZ.
02-13-2019, 08:27 AM #59
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,989
- 679
- 1079
- 1917
- 7940
- 4 Post(s)
under 200
200 to 400
400 to 600
over 600
You want the updated compressors
baja1000 thanked for this post
02-13-2019, 01:06 PM #60
5000 RPM
- Sep 2012
- Florida
- 446
- 15
- 9
- 85
Rebuild at 600hrs? Aren't you a tad bit pessimistic there?
24 skater 15 inch motors
By Risco in forum General Boating DiscussionReplies: 32Last Post: 04-24-2017, 08:47 PM -
21 skater less motors
By 2jz in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 10-01-2015, 04:33 PM -
Wanted Skater 24 or 28 with motors
By 4-MULA-V in forum Hulls WantedReplies: 2Last Post: 09-28-2014, 12:50 PM -
Skater 21 with twin motors
By skateracrossthepond in forum Technical DiscussionReplies: 15Last Post: 12-20-2011, 09:51 PM -
30' Skater, Motors turning IN or Out??
By 28 skater in forum Props, Setup, and RiggingReplies: 3Last Post: 03-05-2010, 06:44 PM
