Results 1 to 9 of 9
Thread: Omc ignition wiring question
02-07-2019, 08:35 AM #1
Screaming And Flying!
- Miami,Fl
- 7,057
- 154
- 83
- 1460
- 382
I have a 1978 johnson 2 cylinder 55 no trim it came on a pontoon boat there is no red plug instead they ran the wires through a clear tube through the motor and I have no idea which is what. Green,red,white,black,blue,yellow all with round connectors and light purple no connector. I'm trying to hook a key switch looks like 6 terminals. I would say it was Micky mouse but it is neat and was probably done by dealer. Any help appreciated. thanks Rick
02-07-2019, 09:41 AM #2
- Miami,Fl
- 7,057
- 154
- 83
- 1460
- 382
Also on the block I see where a window was welded I figure this engine was like the ones a small dealer in De used to do waranty work they would repair that engine. Omc use to have them fix the engines like many other dealers when omc went down they lost a bundle.
02-07-2019, 10:40 AM #3
Banned
- Jan 2015
- Wisconsin
- 2,327
- 458
- 343
- 6429
- 5148
- 4 Post(s)
02-07-2019, 10:41 AM #4
Banned
- Jan 2015
- Wisconsin
- 2,327
- 458
- 343
- 6429
- 5148
- 4 Post(s)
As far as a window welded back up, no idea. Pictures might help.
02-07-2019, 12:46 PM #5
- Miami,Fl
- 7,057
- 154
- 83
- 1460
- 382
I have none of those colors I have straight colored wires this if I knew how to post pictures from my phone I would. thanks
02-07-2019, 04:28 PM #6
The ignition switch should have letters for each of the functions. You'll have to figure out what your wires are hooked up to. You should have a 12 volts(all the time...probably from the starter solenoid) which would go to the B on the switch...wire from the choke/primer will go to the C.... the I on the switch will power your gauges...G on switch to ground...S to the starter solenoid/safety switch...T to the grey wire on rectifier and the K will go to the kill wire on the CDI....pretty sure those are the letters on a normal push to choke switch.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
delawarerick thanked for this post
02-07-2019, 05:11 PM #7
Only way to be sure is to verify colors on the engine side connections , the guy may have been a yamaha mech those sound like yami 10 pin colors and they use the jap connectors... do a search prob find a color code..Dave
02-07-2019, 07:17 PM #8
Or just go right to the motor and see what color wires go where and mount to the switch.
Hustler 16' Victor
Hustler 16' Victor
02-07-2019, 08:18 PM #9
- Miami,Fl
- 7,057
- 154
- 83
- 1460
- 382
It looks like yamaha colors and I think I need a 6 post omc ignition
Ignition wiring for my 2.4 Bridgeport
By 15 Mustang in forum Props, Setup, and RiggingReplies: 0Last Post: 08-14-2008, 09:30 AM -
Ignition wiring question !!!
By crazy cajun 2 in forum Technical DiscussionReplies: 1Last Post: 11-03-2006, 10:15 AM -
ignition switch wiring
By JIMK in forum Technical DiscussionReplies: 3Last Post: 06-26-2002, 10:21 AM
