Results 1 to 15 of 17
    Feb 2011
    HUDSON, FLORIDA
    Temp alarm stopped its normal beep on start-up
    MY 225 STOPPED its reg beep. i grounded temp wire.. still silence? is the buzzer in the control box? i dont think i grounded the correct way. my electrical skills are limited. its the only alarm on motor.
    Jan 2008
    SUMMERVILLE S.C.
    the buzzer should have 12v to it any time the key is on.. if it runs hot the sender grounds it and the alarm goes off.. when you first switch it on it grounds and beeps to let you know that it's working...find the buzzer , switch key on , check for 12v , ground the other side ...it should blow..if it does not , then the horn is bad....if it does , then figure out why it's not grounding..
    should be in harness near key switch
  4. Likes Dave Strong liked this post
    If the key is in the control box warning horn should be inside, key in dash will be at ft of harness like Vnemous stated.
    Quote Originally Posted by Dave Strong View Post
    I assumed that because this is a High Performance boat site he would have and Incontrol shifter and a foot pedal like the rest of us.missed the control box part
    81649A1 is part number if in box.
  7. Likes Dave Strong liked this post
    Feb 2011
    HUDSON, FLORIDA
    Key is in control box but horn is behind dash pretty sure black plastic disk with a blue and white wire has to be beeper. ill see if blue is 12v with key on, grounding white should energize horn. thanks guys. i cant run with alarm disabled.
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by BOATMANBLUES View Post
    ive got 3 wires onport sensor 1 says gauge other 2 seem like pairs, should i be checking the single marked gauge?
    TX......somewhere?
    port side, gauge means "temp gauge"... over heat is in starboard head.. single tan/blue wire.. it is tha wire you can ground to test buzzer also.. 2.5 or 3.0 motor?.. oiler still work?.. if so then it could be tha oiler warning module.. it is what makes tha buzzer test beep when key is turned on...
    what motor?.. may have an OEM manual in pdf for it.. can send it to ya if I do have it..
    Feb 2011
    HUDSON, FLORIDA
    reply
    ok grounded starboard wire horn sounded. just cant get the test beep. on start-up. beeper is behind dash, key in box, using foot throttle. 225 pmx non-oiler no modules. im 99% sure i heard a beep after rigging and turning key 1 st. time. not even sure anymore. what mystery part gives the 1 test churp? stumped....
    Feb 2011
    HUDSON, FLORIDA
    TX......somewhere?
    no oiler module, all test beeps go away.. won't get anything with it gone.. jus get over temp alarm when/if that happens..
  14. Thanks KIRCHNER thanked for this post
    No module no test beep on start up.
  16. Thanks KIRCHNER thanked for this post
    Feb 2011
    HUDSON, FLORIDA
    I GUESS i am hearing things????? old age setting in...
  18. #14
    Jul 2002
    FT WORTH, TEXAS
    Yep all post above are correct on the no box no beep think nothing about the getting old situation i have things falling off me at a very rapid rate at this point in my life at 73 the outlook for future impairments looks bright
  19. Likes Dave Strong liked this post
  20. #15
    TX......somewhere?
    Quote Originally Posted by KIRCHNER View Post
    thought tha same thing but my little bride says I can't hear ****....
    right along with bobby on tha rest of tha story.
  1. Replies: 11
    Last Post: 06-25-2017, 12:04 PM
  2. OMC Tech: 1989 johnson 70 hp stopped running an cranks but wont start only backfires
    By husseyford69 in forum Technical Discussion
    Last Post: 08-17-2012, 04:27 PM
  3. OPtimax 4 beep alarm
    By luckycraft in forum Technical Discussion
    Last Post: 05-28-2009, 10:05 AM
  4. Promax 300 alarm beep after overheating
    By 86 apache 22 in forum Technical Discussion
    Last Post: 07-27-2006, 07:08 AM
  5. BEEP BEEP BEEP Water/Fuel Seperator
    By HighVelocity in forum Technical Discussion
    Last Post: 07-12-2006, 07:43 AM
