Results 1 to 5 of 5
Thread: 2.4 heads on 2.5 block
12-26-2018, 05:23 PM #1
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,950
- 596
- 100
- 519
- 630
what would be the best way for swap, pull out dowel pins from 2.5 block or use 2.5 gasket and drill 2.4 head to work with 2.5 pins? hope JAY chimes in! merry christmas to all.
12-26-2018, 06:26 PM #2
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
The only way I have seen it done is to pull the pins from the 2.5 block.
I am working on a clamshell cowl bracket for the 2.5 and it would be cool to run 2 piece 2.4 heads on it. I kinda got sidetracked on that project so it may be a while...Josh Peterson
12-26-2018, 06:31 PM #3
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
Did the clam on 2.5....keep what heads the motor is made for.....Unless ya MAD Scientist...Just cut the heads....
nitro_rat liked this post
12-26-2018, 08:22 PM #4
5000 RPM
- Aug 2006
- GA
- 865
- 25
- 37
- 73
Get 2.5 heads
12-26-2018, 09:12 PM #5
If you do use the 2.4 heads be sure you get the 2.5 gaskets. Piston could hit a 2.4 gasket.
RockTeam Junk
KIRCHNER thanked for this post
Can 2.4 heads be used on a 2.5 block?
By coffeeguy in forum Technical DiscussionReplies: 8Last Post: 01-11-2019, 06:11 PM -
2.4 heads on 2.5 block using 2.5 gasket?
By Magcat 62 in forum Technical DiscussionReplies: 6Last Post: 04-07-2017, 01:41 PM -
By coffeeguy in forum Technical DiscussionReplies: 0Last Post: 05-16-2015, 07:18 PM
