Results 1 to 9 of 9
    May 2010
    Germany
    Negative Squish Angle on 2 Stroke
    The original 3HP 2stroke Yamaha Malta does have a negative squish angle (I checked 5 of them)
    So it is not done by mistake from the Japanese. They wanted them like it is.
    I read that a negative squish angle in most cases does not make sense. But when it does make sense?
    Due to that i cant find an answer on internet i'll try and ask you guys!
    Does anybody know?
    TX
    Oliver
    Dec 2001
    Might be for piston clearance....when piston rocks?
  3. Likes Instigator liked this post
    With taper opening to the center of the crown, likely tries to creates a tumble of the front. Minimum clearance on the the outside circumference would probably need to be even tighter. Just speculating .
    Did you measure the piston height verses the deck at TDC?
    12 Post(s)
    Great guess.
    Ive never heard of it.
    Makes zero sense in terms of power.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Feb 2014
    Missouri
    Some older motors have bifurcated pistons, to promote flow. Negative squish is the same idea.
    It it can be bad on a 4s but on two strokes it promotes flow out the exhaust to keep it from going out the intake.
  7. Thanks Instigator thanked for this post
    Likes Slimm, ostsideend liked this post
    Quote Originally Posted by ostsideend View Post
    Does anybody know?
    TX
    Oliver
    Yes, A negative squish angle will increase charge velocity in low compression, low horsepower, low RPM, applications like 3 hp Yamaha's, which would tend to foul spark plugs easier without it.
    Their thinking is, if you want more power ... buy a bigger motor ...
    If your dead set on building the baddest *(^$^&*&(% 3 horse on the planet ..
    then go 1 to 3 degrees positive . It will be less prone to detonation and will have a few hundred rpm over rev compared to a parallel squish/crown .
  9. Likes Instigator, Slimm, ostsideend liked this post
    May 2010
    Germany
    Thank you guys for your answers!
    i already changed one head to a small positive angle!
    That alone will lower compression. But it does open the door to cutting the head to raise compression not only to where it was before, but a little higher ( depending on gas quality ) to pick up a little power.
  12. Thanks ostsideend thanked for this post
    Likes Slimm liked this post
  13. #9
    May 2010
    Germany
    Fully agree. Head does give 11:1 ratio now. Fuel is 102 Oktane.
    When i found the negative angle, i thought the japanese have wide tolerances or the pre owner put in a different piston for some reason. Later i read about existing negative angle designs and could not explain it to myself.
    TX again!
  1. squish angle help please
    By nz dave in forum Technical Discussion
    Last Post: 05-24-2009, 09:59 AM
  2. Negative jack- 5 iches down- please help!!!
    By BASS-O-NOVA in forum Props, Setup, and Rigging
    Last Post: 09-10-2008, 07:29 PM
  3. Float angle VS running angle ?
    By WATERWINGS in forum Technical Discussion
    Last Post: 03-16-2007, 09:10 AM
  4. Trophy negative slip?
    By David in forum Props, Setup, and Rigging
    Last Post: 05-31-2005, 06:58 PM
  5. Angle of attack VS trim angle?
    By Techno in forum Technical Discussion
    Last Post: 03-03-2003, 09:00 AM
