Results 1 to 15 of 21
Thread: Reed Block
    Dec 2003
    Reed Block
    Hello all..
    Currently working on a 125 (2 + 4).. Specifically reed and reed replacement ( 9 Pedal). Mercury Service Manual indicates the reed bolt torque of 80 In LBS.. This torque spec seems a bit much for this reed block. Can anyone confirm this torque? I read elsewhere a torque of 20 In LBS is more realistic.
    Thanks
    Sep 2017
    Ashland city tn
    The 20 sounds better to me but Carson will have the answer
    Dec 2003
    Mr. Carson.. Would you care to chime in sir?
    Aug 2015
    NE Tennessee
    80 in Lbs is less than 7 ft. Lbs.
    However I am not familiar with the motor your working with.
    Shop manuals (factory manuals) are seldom wrong, or have misprints that don't get corrected in subsequent revisions.
    Last thing you want is one of those fasteners to come loose. Some folks use loc-tite with these small retainer bolts/screws.
    Sep 2017
    Ashland city tn
    Yes always use blue loctite
    Dunnellon, Fl. / Cincinnati, Oh
    I've seen overtorquing them lift them off tip of tip reed block. Be Careful!
    Chaz = thinkin that ifin ya cant figure out that the pound and a half is for the reed pedal screws and the seven pounds is for the allen bolts that hold the blocks to the adapter plate. Then in all sencerety, maybe you should take your boat to a shop and have the work done for you.
  8. Likes ssv1761982 liked this post
  9. #8
    Nov 2016
    Missouri
    Or you could torque the reed attaching screws to 2.8N-m and the and reed block mount bolts to 9.0 N-m...
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
  10. #9
    Is there an echo in here ....
    Chaz = wanting to see Bruce's "Nanometer only" torque wrench sitting on todays newspaper ... proof of life ..
  11. #10
    Nov 2016
    Missouri
    My torque wrenches have both readings on them Nm on back and ft or inch pounds on front and yes i have ft lbs and inch pound torruing devices...no picture since the torquing devices are at the shop and they are top secret...
    1995 200 XRI
  12. #11
    Dec 2003
    I have found torque spec inconsistancies within Mercury Service Manual. For example, Mercury calls for a troque of 100 in lbs for the air box plate bolt(s). 100 in lbs WILL crack the air box plate., I've seen this over and over again. I torque them to 60 and have never had a problem.
  13. #12
    Dec 2003
    I will go ahead and remove the reed block screw with a torque wrench. I will consider that the factory most likely applied red loctite to the threads. By heating the bolt ever so slightly this should soften the loctite enough and maybe give me a ball park torque for the bolt.
    Thanks all for the replies..
  14. #13
    Nov 2016
    Missouri
    Newton meters Chaz..Click image for larger version.
ID:	424649Click image for larger version.
    1995 200 XRI
  15. #14
    Sep 2017
    Ashland city tn
    Quote Originally Posted by pbxcomm View Post
    Red is never used on reeds in a regular practice. Always blue even n manual do you have a merc manual? Money well spent if not. All info
  16. #15
    Nov 2016
    Missouri
    My Merc manual for 5 and 7 pedal reeds show 25INCH pounds for reed attaching screws and 80 INCH pounds for reed block mounting bolts.This is a 135 to 200 horse merc OEM manual.
    1995 200 XRI
  17. Likes W2F a V-King liked this post
  1. reed block
    By xskeetshooter in forum Parts Wanted
    Last Post: 05-03-2014, 12:40 PM
  2. what is the boyseen reed part# for a 4 petal reed block
    By camaro7081 in forum Technical Discussion
    Last Post: 03-15-2007, 08:54 AM
  3. reed block
    By ptextreme in forum Technical Discussion
    Last Post: 06-05-2006, 09:10 PM
