				Results 1 to 6 of 6
		Thread: Small holes in bottom
	11-22-2018, 06:08 PM #1
						Junior Member
 - Sep 2018
 - oh
 - 22
Getting ready to lay in the 1708 and balsa, and noticed some small holes in the bottom (some I made and some were small punctures). So I cleaned them up with small dremel.
To prevent resin and mat from dropping through the holes, I thought I would apply tape on the bottom(to save grinding when I flip it over)
Good idea?
What kind of tape?
				NICE PAIR liked this post
	11-22-2018, 06:29 PM #2
Perfect.
Masking tape. Resin won’t stick to it.
Mix up some resin/cabosil and microfiber (1/8” glass fiber) and fill the holes when done.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
	11-23-2018, 08:38 AM #3
						Junior Member
 - Sep 2018
 - oh
 - 22
Great. Thanks. Some instructions say to wet surface with resin before laying in the mat. Does mean resin with or without hardener?
	11-23-2018, 10:08 AM #4
						7000 RPM
 - Mar 2009
 - Port Saint Lucie
 - 2,530
 - 31
 - 256
Pre wet the dry boat with mixed resin before you put down the glass.
	11-24-2018, 01:42 PM #5
						7000 RPM
 - Feb 2005
 - seattle
 - 2,654
 - 17
 - 33
i've had goos luck with clear packing tape. i only use epoxy on hull with fully cured resin. vynalester [sp] resin may also work, but i just prefer the epoxy. i would use tec-mix to plug the holes up from the bottom. the t-m has very good abrasion resistance.
	11-25-2018, 12:46 PM #6
						6000 RPM
 - Sep 2002
 - Solvang, Calif
 - 1,459
 - 78
 - 29
 - 160
 - 156
I poked a couple of holes thru the bottom of my boat, DUH. Didn't want to just cover them up on the inside and have them pop off inside the boat one day while running down the lake at 95mph. So... on the outside I beveled the hole. Then put a layer of tape tight outside the hole but loose over the hole. Poked a pin thru the tape to let trapped air out. Then pushed the spooge thru the hole making a bump on the outside. In my mind it looked like an hour glass.
Gary
best way to fill holes throught bottom of boat
By lbhsbz in forum Fiberglass and Composites DiscussionReplies: 3Last Post: 06-05-2018, 05:27 PM -
What the best filler for small holes on gelcoat
By bravo 1 in forum Appearance ModsReplies: 13Last Post: 07-16-2011, 09:23 PM -
Small holes in lower unit
By hemi2005 in forum Technical DiscussionReplies: 7Last Post: 04-01-2010, 02:45 PM -
Difference in 2.4 head gaskets? (big holes vs small holes)
By WATERWINGS in forum Technical DiscussionReplies: 3Last Post: 10-18-2006, 08:59 AM
