Results 16 to 30 of 39
    Oct 2005
    savannah,ga
    What will I need to get for a repower?Everything is original from '94. Faria gauges,mechanical steering,side mount controls.Also the Pro XS has a torgue master foot,will that work?
  2. #17
    Mar 2017
    redondo beach, ca
    You will need the 14pin plug/cable and wire it accordingly. There is no room under the cowl for an adapter. Not sure about the steering but my hydraulic set up mounted to it no problem. With the torque I recommend a hydraulic set up. The lower unit will not work so but the pro xs is not much more and comes with a torque master. (Wait time was too long for me). I would set aside a grand or so for transom investigation and repair/bracing. Might as well make sure your package is solid and trouble free.
  3. Thanks JBS thanked for this post
  4. #18
    Feb 2003
    Bellingham, WA
    Great thread, and thank you for the real world information.
    These kind of posts are truly why S&F is such a great website!
    Please continue to post updates
    22' Activator w/ 250xs Merc Opti, back home again
  5. Likes tux974, Toffen liked this post
  6. #19
    Mar 2017
    redondo beach, ca
    Update: I took the boat out again but this time in the Pacific ocean (socal). It was pretty choppy with winds blowing 8knts and steady 2ft ground swell.
    Fuel: averaged 5.3mpg with an average speed of 42mph
    Handling: much better than expected, with the larger diameter 4 blade the motor still felt hooked up (while in the water).
    Noise: louder in the chop as the prop was out of the water much more, I was actually able to hear the engine above 40.
    Motor mounts: way to soft.. but I'm going to compare pn#s with the 300r and see what it's going to cost when these go bad.
    Prop slip top speed: pretty bad slip in the chop, I was able to get it up to 68mph at 5200. The gf was pretty upset and wouldn't let me get into it any more but such is life.. I suppose I'm terrified when she drives on the freeway so it's fair. Prop slip would be 19 percent which makes me think a smaller pitch 5 blade may work better. Maybe a labbed 28 or 26? Recommendations would be appreciated
  7. #20
    Jul 2004
    Connecticut
    What exact prop do you have on it? I may have missed it earlier.
  8. #21
    Mar 2017
    redondo beach, ca
    Rob hill signature 4 blade 30"
  9. #22
    Jul 2004
    Connecticut
    Check and get the diameter of that model. I'd assume you would want to try something with more diameter in 4 blade to just do a quick compare.
  10. #23
    Jul 2018
    LOTO
    I have a 32P 5 blade Hill Marine on my 300r Liberator right now and really like it. I gavee up some top end, but gets out of the hole and accelerates like right now with 3 people on board.
  11. #24
    Mar 2017
    redondo beach, ca
    King of beers, I think the liberator 21/300r combo is a lot lighter than mine and is able jack the engine higher. But Im thinking the 5 blade is what I should shoot for in 28" does your 5 blade crab walk or have a lot of torque steer? I'm not sure if the sporty skeg is different than what I have. I may end up waiting to change props untill I cone it and have the torque tab done.
  12. #25
    Jul 2018
    LOTO
    Quote Originally Posted by madmatic View Post
    im sure im a lot lighter, i notice zero torque steer or any crabbing. The 5 blades are 15.6" dia. Great prop for the money IMO. Boat looks great! I drooled over a twin Alley Cat years ago.
  13. #26
    Mar 2017
    redondo beach, ca
    Thanks for the info and compliment. Looks like a 26-28" sl 5 blade is in my near future
  14. #27
    Aug 2002
    Homosassa
    I'm going to repower my fishing boat (Scarab 302) with a pair of these. What White did you choose (Hot Fusion, Cold Fusion or Pearl) ???
    Just Duck'n Around
  15. #28
    Mar 2017
    redondo beach, ca
    Cold fusion white.
  16. #29
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    Also the 300l and R are the exact same long block, same cams, pistons ect.
    I'm just gonna leave these here...
    In the next two pictures, please note the differences in the intake runner part numbers in the lower right hand corner.
Name:	300ProXS Intakes.PNG
Name:	300R Intakes.PNG
    A problem is only a problem when viewed as a problem...
  17. Thanks madmatic, Todd D thanked for this post
    Likes Greg G, Todd D liked this post
  18. #30
    Sep 2007
    bay city mi.
    Same exhaust cams. Loks like the 300 pro xs shares intake cams with 250r
  1. 24' Sanger AlleyCat, ready to go
    By treystjohn in forum Hulls larger than 20'
    Last Post: 04-26-2019, 03:57 PM
  2. Photos: '79 Sanger 21
    By mwidden in forum General Boating Discussion
    Last Post: 08-14-2014, 10:44 AM
  3. mid section johnson 300v8
    By m3mm0s rib in forum Technical Discussion
    Last Post: 05-17-2013, 11:16 PM
