Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 51
    TX......somewhere?
    Quote Originally Posted by KIRCHNER View Post
    IHAVE a loose green wire and my oil alarm still works so it must be for det / knock sensor i removed all boxes execpt alarm.
    if ALL boxes removed you can't get anything except an over heat sensor, solid "buzzer" alarm.. should not be any loose green wires... only loose wire should be a gray/white (knock sensor) from tha harness.. needs ta be grounded anywhere on tha block..
  2. #17
    Feb 2011
    HUDSON, FLORIDA
    T ONYtold me to unplug tps with his new acu. im sending mine back with my old ecm i cant keep mota running, flooding all 6 cylinders, tried everything tested all senders. im going to put my old ecu on 1 more time clean all plugs and see if it will idle. strange it was running ok with new acu and then got weird, smoking, choking and stall. wont start back up now. plugs all soaked. like injectors are all wide open. i think you didnt have a good ground somewhere. u got better luck than me. ART
  3. #18
    May 2017
    Ca
    It’s running great now. Idling good and revving on the trailer. Gunna try to get it in the water Saturday. And I know I had a good ground I even ran a extra ground to the water separator screw just for ****s n giggs.
  4. #19
    Feb 2011
    HUDSON, FLORIDA
    YES i do have 1 box my mistake still have a disconnected green wire coming up port side from coil harness.? im thinking that 1 box is my oil alarm. ill look for that gray/ white wire, would that have gone to head knock sensor? thanks.
  5. #20
    TX......somewhere?
    assumin' ya no longer have oil injection.. that would be for tha rotation sensor... no longer needed along with module... gray/white yeah, it may have a female bullet connector on it.. comes outta tha harness.. gray/white from det. module was plugged into it.
  6. #21
    May 2017
    Ca
    My green is coming out of the coil harness. And your 1 box is probably the idle stabilizer. That’s the only box I have left.
  7. #22
    Feb 2011
    HUDSON, FLORIDA
    I DO have my oil injection operating, idle box removed. my oil alarm is supposed to be still operating, but have that green wire, going nowhere. your saying i dont have the rotation alarm? a mecury mech did the work now im confused. i wanted my oil alarm only.
  8. #23
    TX......somewhere?
    if tha green is on a coil and goes no where?.. was originally going to tha det module and is no longer used....
  9. #24
    Jul 2012
    Lufkin, Texas
    This was originally bunger’s thread about oil injection removal. KIRCHNER, I think you should start your own thread about removing the timing modules but keeping the oil injection. This is getting confusing!
    Josh Peterson
  10. #25
    May 2017
    Ca
    Hahaha. Does anyone have any ideas why swapping the ECUs back and forth randomly got the thing running?
  11. #26
    TX......somewhere?
    harness?.. usually continious "in and out" action leaves most happy!......
  12. Likes nitro_rat, Bunger liked this post
  13. #27
    Feb 2011
    HUDSON, FLORIDA
    this was originally bunger’s thread about oil injection removal. Kirchner, i think you should start your own thread about removing the timing modules but keeping the oil injection. This is getting confusing!
    i agree.
  14. Likes nitro_rat liked this post
  15. #28
    May 2017
    Ca
    Just noticed the bottom left corner of the exhaust divider looks like it’s blown out. Is it okay to run for a hour or two like that on Sunday to test the acu or should I fix it first?
    Attached Thumbnails Attached Thumbnails 4FB63A90-E6E5-4D0F-B275-4665ADD6D0C2.jpg
  16. #29
    May 2017
    Ca
    Also pro marine has a standard and metal gasket. What one am I getting?
  17. #30
    May 2017
    Ca
    Anyone?
  1. oil injection removal
    By ttopping in forum Technical Discussion
    Last Post: 03-04-2018, 09:09 AM
  2. 225 Promax removal of oil injection and timing module done right
    By woundedwarrior in forum Technical Discussion
    Last Post: 09-01-2014, 07:59 AM
  3. 300 promax oil injection removal
    By jaybluez in forum Technical Discussion
    Last Post: 08-11-2013, 10:18 PM
  4. Mercury Tech: Removal Oil Injection 3.0L efi with S/C
    By Bensy in forum Technical Discussion
    Last Post: 05-05-2010, 08:43 PM
  5. Oil injection removal
    By cajunman72 in forum Technical Discussion
    Last Post: 01-10-2010, 02:00 PM
