Results 1 to 15 of 18
11-10-2018, 11:12 AM #1
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
Yamaha Malta 3HP tuning for fun to presently 7.4 @ 5300
The progress on my 3Hp 70ccm 2stroke Yamaha Malta is as follows:
I am jusing a DIY hydraulic dyno with an electronic torque wrench on it. Data are "collected" by doing a video and typing them into a ecxel chart as many as i can. Then i kick out these who will not realy fit to the others. I think i get relatively reliable data doing this this way.
Sorry for the poor vid quality, but i had to handle my phone and the hydraulic valve wheel while stopping to breeze
(Have to search for a nicer smelling 2stroke oil)
https://youtu.be/XAemR-L8sUc
Samuel von Bagh thanked for this post
11-10-2018, 02:36 PM #2
Junior Member
- Oct 2017
- TX
- 7
I love it.
What mods have you made so far to the engine?
Rob
ostsideend liked this post
11-10-2018, 07:58 PM #3
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
This one does have digital inner rotor ignition with a nice preignition curve fix programmed in the cdi, Glass Fiber Membran in stock housing, kart Membran carburettor tuned to slightely lean condition (A/F Ratio) with 16mm venturi only and 11:1 total compression ratio with .6mm squish band (approx. 40% of the bore)
Rest of "Block" and exhaust are stock!
next Target are 10HP @ less than 7,000 rpm (becomes much more difficult)
i will use another block with more rpm willing degrees of exhaust timing and surface space...
sorry for autocontrol typing on mobile pad combined with ginglish ;-)Last edited by ostsideend; 11-11-2018 at 11:31 AM. Reason: changed the word -effektive- to -total-
11-10-2018, 08:09 PM #4
Pictures of the dyno please, cool project!
11-11-2018, 12:29 AM #5
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Schnurle ?
11-11-2018, 05:13 AM #6
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
Yes, with inlet into crank case.
11-11-2018, 07:23 AM #7
Junior Member
- Oct 2017
- TX
- 7
That is an incredible amount of effective compression. What is your cranking compression reading? What type of fuel?
Can you provide bore/stroke/rod length please?
Pictures, we love pictures.
Rob
11-11-2018, 10:37 AM #8
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
.6 , zero deck , gasket material?
11-11-2018, 11:25 AM #9
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
Hi Rob,
you are fully right. I did not use the correct word. it is 11:1 total! ( i will correct this in my above post)
(Bore 42mm stroke 46mm) : (combustion volume)
We can get up tp 102 OCT = approx 98 AON at gas stations. If i leave it at 11:1 i don't have to mix it with i.e. Toluol.
Timing checked with a degree wheel
The timing of a stock block is very low and one of the reasons why it dont like to go to higher rpm.
But the low data gives low rpm torque...
Intake 110°
Exhaust 150°
2 transfer channels only, but huge! Exhaust port gives a chance of positive influencing.
Ignition and carb changed
Tested on a hydraulic brake Dyno
enough pics?
FMP liked this post
11-11-2018, 11:39 AM #10
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
11-11-2018, 11:47 AM #11
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
11-11-2018, 11:52 AM #12
Junior Member
- May 2010
- Germany
- 28
- 12
- 7
But the next step i'll do is with another block. (slightely changed exhaust timing) using the above shown head. I will enlage the intake membran to max more surface (8 carbon blades) and cut another block in pices to see how much space i have to widen the exhaust channel before i brake into cooling channels.
from left to right: stock 3pcs steel reed, little more surface and 2 glass fiber reeds, huge surface and 8 carbon reeds
I'll see...Last edited by ostsideend; 11-11-2018 at 11:57 AM.
11-11-2018, 06:31 PM #13
- Dec 2001
- 9,501
- 271
- 191
- 1979
send this guy a 9.9 rude.......
11-11-2018, 06:44 PM #14
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Or a 78 8hp 164cc looper CHRYSLER with low water pickup lower unit, 53lbs, squash that 9.9!
Zero deck, piston height in bore in relation to deck at TDC.Last edited by FMP; 11-11-2018 at 08:46 PM.
11-11-2018, 09:31 PM #15
5000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Yamaha Tech: V6 yamaha carb tuning
By Bruce C in forum Technical DiscussionReplies: 5Last Post: 03-17-2018, 02:55 PM -
Boating not good in my area presently Two wrecks.
By Smoking Joe in forum General Boating DiscussionReplies: 5Last Post: 10-14-2011, 02:13 PM -
Yamaha v4 115 tuning help??
By james111089 in forum Technical DiscussionReplies: 4Last Post: 11-14-2006, 07:27 PM -
yamaha 225 from 1999. tuning ????
By morpheus in forum Technical DiscussionReplies: 3Last Post: 01-26-2006, 08:52 AM -
130 V4 Yamaha Tuning parts ?
By mahharhja in forum Technical DiscussionReplies: 7Last Post: 03-29-2002, 07:47 PM
