Results 1 to 7 of 7
    May 2001
    Maine
    Mercury 1.25" solid hub inserts
    Does anyone know if its possible to purchase the 4 plastic/ teflon inserts that attach to the Mercury solid hub - #840389 K06? Is there a part number?
    Thanks...
  2. Likes lance liked this post
    Jun 2002
    Northern Utah
    Yes,
    840382A02 black snubber strip replacement kit
    May 2001
    Maine
    I expect the way to determine if they need replacement is to slide the hub into the prop and ensure its "snug" fit with no metal to metal contact(?)
    Jun 2002
    Northern Utah
    I guess they could wear out but I've had more of a problem just keeping them glued on. I've even seen new hubs with the strips loose in the box.
    I have experienced the same hub fitting tight in one prop but loose in another.
    I think if all 4 of the snubber strips are attached to the hub and you torque the nut down properly, you will be fine.
    May 2001
    Maine
    I was thinking of trying some 5200 adhesive silicone to re glue my loose strips.
    Use bellows ashesive
  8. Likes Dave Strong liked this post
    Aug 2010
    Barrie, Ontario, Canada
    Is there a part number for the round plastic inner insert in the hub? Not sure if it wears down over time causing a little bit of play on the propshaft?
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  1. Mercury Outboard Cowl hose inserts??!?!?
    By Superboat Rob in forum Props, Setup, and Rigging
    Last Post: 03-13-2007, 08:10 PM
  2. EGT extension wire type K "solid?"
    By B.Mac in forum Technical Discussion
    Last Post: 03-16-2004, 10:35 PM
  3. x-flow v-4 solid mounts? "pinning"?
    By sixabove in forum Technical Discussion
    Last Post: 05-28-2002, 10:51 AM
