Results 1 to 14 of 14
    Mar 2009
    Huntington,Tx
    Switch box blues
    Hello my ? is is it possible for both switch boxes to go out? Last weekend ran great all the way back to the trailer. set up all week went out today backed in the water to launch fired up running about 2k and when idle down to 900 it would die. wouldnt get on a plain and missing like crazy. brought home pulled plugs marked flywheel for each cylinder got the wife to spin over while checked each cylinder for fire the only cylinder firing perfect was 6, 2 would fire some nothing on 4 ,and nothing on 1,3,5. just seams weird that both could go bad. has anyone had this happen ?
    Thanks in advance
    1997 XB2003T gone but not forgotten
    Aug 2002
    Palm Harbor, Fl../ lake tarpon
    This happened to a buddy of mine the other day only he has no fire on 3 and 6 but he also ran the motor for a day or two on 5 cylinders so I'm thinking I haven't checked it yet but it may be the stator or from running it like that he may have burned up to never know till I check it out
    02 mirage ski racer w/ 2.5
    lake tarpon (LTB racing)
    "Mirage Boats... often imitated but never duplicated"
    Mar 2009
    Huntington,Tx
    Quote Originally Posted by toyomirage02 View Post
    Im thinking some trigger issues, going to check out more Saturday. Thanks
    Jul 2002
    FT WORTH, TEXAS
    im thinking trigger myself just my .02
  5. Likes Aggressive Machines liked this post
    Jun 2018
    Floating around
    Im the new fish with one merc repair under my belt and Im going with stator or cracked flywheel magnets
  7. Likes Aggressive Machines liked this post
    Mar 2015
    Vancouver, Washington
    Keep us posted, the stator, Trigger, switch box, or coil, question seems to always be a riddle.
    Whitney Woolard
    Oregon/Washington
    '96 Allison XB2003 w/Mercury 2.5 260ss
    Change the Flywheel and see if that corrects the problem before doing anything else. If it does the Hub Magnet has moved. its not uncommon here lately. These Flywheels are 20+ years old. Ive had 4 Hubs go bad in Three years and every time its acted different like trigger or bad Switch boxes. .
    I just freshened up one of my rebuilds of 15 years ago that was still running great but had mysteriously developed a squeak , like an upper bearing failing but had not lost an rpm in 15 years of trouble free service , I tore this thing down and miked every component to find nothing wrong , even the TDR reeds were perfect , long story short I polish the two tapers on the crank and flywheel and after a close inspection the flywheel hub was cracked completely thru from the bottom of the hub all the way thru the splines , so like Bud suggested don’t assume that the flywheel is ok , call me and I’d be glad to tell you a method I use to check flywheel magnets health..
    832 597 2603
    Jay @ JSRE
    Jay @ JSRE
  11. Thanks HStream1 thanked for this post
    Likes Aggressive Machines, Mike Nass liked this post
    NE Louisiana
    How often do triggers go out though? As far as a stator, I had one go bad and it took one of the switch boxes with it. So I just replaced both. When Merc parts go bad, they can take others with them is what I have experienced.
  13. Likes Aggressive Machines liked this post
    Mar 2009
    Huntington,Tx
    I have an extra 40 amp flywheel, triggers, switch boxes , stator . Being new in to chasing electrical issues has got me stun . I was able to read in the manual and see that the trigger fires the switch boxes, yet the stator supplies high and low power. couldnt work on it yesterday, but about to go turn wrench's today. I had to order a DVA adapter so i cant really do much on checking parts unless someone knows a trick. I do thank all for the info help, and Jay I will call you sir on the flywheel check. Im just surprised how she ran good 1 weekend and the next went to crap before it got off the trailer. Im sure it does not matter but its a 1989 XR4
    NE Louisiana
    My Merc manual said (paraphrasing) if the DVA didn't show the problem, to start swapping parts. I know several good mechanics that keep a spare set of electronics on the shelf just to diagnose. I have a spare set as well.
  16. Likes Aggressive Machines liked this post
    Mar 2009
    Huntington,Tx
    right where the trigger wires come out the fly wheel rubbed in to the wire insulation Click image for larger version.
  18. #13
    Mar 2009
    Huntington,Tx
    dont know what happen hereAttachment 419538Attachment 419538
  19. #14
    Mar 2009
    Huntington,Tx
    Well that was the main problem, I bought this bolt on a while back (xr4) and never noticed this trigger wire issue, installed another trigger and replaced the switch boxes (both) and she is hitting like she should . didnt get to go to the water but can tell the difference . Thanks to every reply it is all good info.
  20. Likes Forkin' Crazy liked this post
  1. Mercury Tech: WH7 blues
    By nitro_rat in forum Technical Discussion
    Last Post: 02-19-2017, 11:02 PM
  2. Winter blues?
    By Xerophobic in forum General Boating Discussion
    Last Post: 02-09-2009, 03:06 PM
  3. 20--20 Blues
    By Tom D. in forum General Boating Discussion
    Last Post: 01-05-2003, 10:20 PM
