Page 15 of 34 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 LastLast
Results 211 to 225 of 496
  1. #211
    Mar 2009
    Saint Lucie Florida
    Definitely feels solid, Anyone have any tips on "blueprinting" / leveling out the bottom?
  2. #212
    Mar 2009
    Saint Lucie Florida
  3. Likes NICE PAIR liked this post
  4. #213
    Mar 2009
    Port Saint Lucie
    Should be done tomorrow. A little putty, a really small 1.5 oz Matt, a 6 inch 1708 and a ripped 1.5oz over the whole thing to blend it in.
  5. Likes NICE PAIR liked this post
  6. #214
    On your blueprinting... Mark a line from each outside chine edge port and star across the transom. Measure up to the strakes and the bottom at equal measurements on each side of the transom. See what you have from side to side for variances. This is the starting point. Use a 6' straight edge or string and go fwd on the hull from the measured points on the transom and see what you have as far as hook and rocker. I usually only concern myself with the back 1/2 of the hull. Main thing is to have close to the same shape on each side of the hull. Some hook is good. Rocker will make the boat porpoise. Flat is good since you can add hook to control ride attitude if needed. If it is about 1/16'' to 1/8'' from side to side it will be ok at your speed level. Sharp strakes will def help performance as will a sharp trailing edge.
  7. Thanks W2F a V-King thanked for this post
  8. #215
    Mar 2009
    Port Saint Lucie
    What he said
  9. #216
    Mar 2009
    Saint Lucie Florida
    Mar 2009
    Saint Lucie Florida
  11. Likes 89LASER, NICE PAIR liked this post
  12. #218
    Torn mat makes such a good transition...Something a lot of people don't take the time to do....
  13. Likes wtsjr66, NICE PAIR liked this post
  14. #219
    Mar 2009
    Port Saint Lucie
    Mat makes everything nicer. It's hard to tell. But the transition from deck to Hull is pretty smooth. Nice and Even. Did a good job.
  15. Likes NICE PAIR liked this post
  16. #220
    I would glass in a block of coosa for the bilge pump to mount to. Unless you plan on using silicone to mount it.
    Rhode Island
    I glassed in a block of wood for everything I mounted in my tunnel hull. DANG - I never thought of just 5200 to hold in my bilge pumps. But that would have worked great. jk!
    A couple rough waves, and that would work it's way loose. Agreed, put a block of coosa down.
  18. #222
    Mar 2009
    Saint Lucie Florida
    Not a whole lot of progress but for a few things done, cut the dash out of coosa and got the seat cut out of H80.
  19. #223
    Quote Originally Posted by home made tunnel View Post
    You would be surprised how well some adhesive caulk will hold a bilge pump. Done many that way and never a problem....
    Mar 2009
    Saint Lucie Florida
    Mar 2009
    Saint Lucie Florida
  22. Likes NICE PAIR liked this post
  1. Evinrude XP200 Rebuild or Repower
    By Stoker88 in forum Props, Setup, and Rigging
    Last Post: 09-09-2020, 11:06 PM
  2. 83 Bullet Rebuild Update
    By One Oldman in forum Fiberglass and Composites Discussion
    Last Post: 06-02-2013, 10:10 PM
  3. 30' velocity rebuild/repower/reeverything
    By biohzrd in forum General Boating Discussion
    Last Post: 08-03-2010, 10:39 AM
  4. Repower advice: OptiMax or rebuild 2.5EFI
    By mercfan1 in forum General Boating Discussion
    Last Post: 11-11-2008, 09:02 PM
