Results 1 to 3 of 3
    Apr 2017
    Orange County
    Normal water psi? 300 promax
    Trying to find correct info on normal water pressure for 1999 300 promax?
    0-5 at idle and anything near 10 at wot is normal. Its volume not pressure with a 3 liter.
    JMO
  3. Thanks Euroski thanked for this post
    Likes NICE PAIR liked this post
    Dec 2011
    Ottawa
    Ya mine is 5 at idle and 12 or so WOT, they are pretty reliable pumps and impellers,they will lose WP over time from the bottom gasket tearing up. Unless you have the updated steel shim gasket.mine pees at idle like a cow on a flat rock,all the volume
  5. Likes NICE PAIR liked this post
  1. Normal water pressure
    By wellcraft17 in forum Technical Discussion
    Last Post: 05-04-2014, 08:12 AM
  2. Normal 2.4 merc water pressure range
    By coffeeguy in forum Technical Discussion
    Last Post: 09-15-2013, 06:39 PM
  3. normal water temp
    By tcrabtree in forum Technical Discussion
    Last Post: 07-24-2009, 08:04 AM
  4. Is it normal to have water coming from this area when running??
    By rchevelle71 in forum Technical Discussion
    Last Post: 01-24-2008, 08:53 PM
  5. no water out of poppet valve at idle!! normal ??
    By camaro7081 in forum Technical Discussion
    Last Post: 05-18-2006, 06:59 PM
