Results 16 to 30 of 30
08-30-2018, 08:01 PM #16
08-30-2018, 08:08 PM #17
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 8,865
- 1084
- 424
- 4812
- 2216
- 9 Post(s)
08-30-2018, 09:05 PM #18
08-30-2018, 09:29 PM #19
- Jun 2007
- 8,865
- 1084
- 424
- 4812
- 2216
- 9 Post(s)
The original electric tilt cylinders fit there i think?
NICE PAIR liked this post
08-30-2018, 10:05 PM #20
5000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
yes they can freeze,used ones are avalible,i'll have to look for mine got rid of most of that stuff-th P.S. we rigged a lot of those motors with the correct/furnished ALUM BOLTS,these four bolts are used to mount motor thru transom.many repowers we find those eaten away-th
08-30-2018, 10:57 PM #21
It's been awhile since I've seen one of the old V4's but I believe what Flabum thinks is a pin is actually the bolt that holds the motor in the transom brackets bolted to the transom. The lever ...if I remember correctly...is for the shallow water drive/tilt...pushed out away from the transom was for holding it tilted out and in against the transom allows it to rest against the transom...the shock are probably seized although I've never seen that happen before...tomorrow I look to see if I still have any service manuals for that motor.
Hustler 15' Wildcat / Merc 80
Hustler 13' Wildcat / Merc 80
Hustler 13' Picklefork (Experimental) / Merc 80
Hustler 16' Victor / Evinrude 85
Hustler 15' Tunnel / Evinrude X115
Hustler 17' Lark / Suzuki 140
Hustler 16' Victor
Hustler 16' Victor / JohnRude 135 (current and restored)
Hustler 15' Family Tunnel / Johnson GT115 (current project)
Hustler 16' Victor
NICE PAIR thanked for this post
08-30-2018, 11:04 PM #22
After a quick check I believe the part # for the shocks is 379148....Ebay has a couple of them but I'm sure they can be found closer to you.
Hustler 16' Victor
Hustler 16' Victor
08-30-2018, 11:39 PM #23
6000 RPM
- Feb 2014
- Missouri
- 1,211
- 66
- 12
- 83
Is this one of the ones that you have to lift all the way till it clicks and then it drops? The auto locker system
08-31-2018, 08:44 AM #24
08-31-2018, 09:33 AM #25
After checking this morning the part # is indeed 379148 and there are 2 of them....that lever on the side does control two tilt positions and the owner should be able to at least remove them for hauling if he wanted to deliver it to you in the down position.
Hustler 16' Victor
Hustler 16' Victor
08-31-2018, 06:30 PM #26
OMC 379148 is made by Prestolite, their # is 379079 I just ordered 2) delivered for $30, Thanks Dan.
On the frozen shocks, He has a very close friend that coming out for some site seeing w his girlfriend, I'm gonna suggest a transom saver from the lower to the trailer. (part of their payment is a boat ride on the CA Delta) ;-)Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
DanUmbarger liked this post
09-10-2018, 04:51 PM #27
I gotz some canoli filling on my favorite Merkury shirt , is it OK-fine if I borrow the Maytag to see if it will warsh-out ...
09-10-2018, 07:07 PM #28
Lol
09-11-2018, 01:08 PM #29
I'm a lil disappointed I haven't been chastized by my buddy the "Instigator" ..
09-11-2018, 06:01 PM #30
Wtf happend to common courtesy ?????????????
By Hot Shot Merc in forum General Boating DiscussionReplies: 43Last Post: 03-13-2018, 12:12 AM -
Nice A$$ courtesy of EastCoastPowderCoating
By resqu-u in forum The Scream And Fly LoungeReplies: 9Last Post: 03-25-2013, 10:45 PM -
NJ: Courtesy Boating Advisory
By Sharkey-Images in forum General Boating DiscussionReplies: 0Last Post: 06-21-2006, 06:13 PM
