Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 31 to 45 of 112
  1. #31
    Feb 2017
    Naples FL
    Rumor has it the tuner works on the whole engine by isolating protons from neutrons causing them to float with a 7% newtonian charge given only by the new solar powered cels used in the tuning module. These cels are designed to harmonize the light and heat into a gamma pattern that runs a b-spline polynomial through its algorithm for this effect. Green technology is amaze balls, i am humbled in awe of these new tuners
    The lake x guys must be partying with the dudes from area 51 LOL
  2. #32
    Mar 2017
    redondo beach, ca
    Hopefully the free valve tech will come to outboards, then you would have no cams, tensioners, or timing chain. So save what 80lbs right there? Then you could have the option to run as a two stroke and bingo you have a 4.6l v8 2 stroke with out ring eating ports and no oil injection or mixing. Also you could put in a timing switch and run as a 4 stroke for cruising and better mpg
  3. Likes powerabout liked this post
  4. #33
    Forward only gearcase, engine could run backwards......
  5. Likes powerabout liked this post
  6. #34
    Jan 2017
    Albany NY
    You guys are losing it.
  7. Likes engineermike, NICE PAIR liked this post
  8. #35
    May 2016
    keys
    New drive system is next, flexible weed whacker shaft will keep the case nice and slim.
  9. #36
    Jan 2017
    Albany NY
    Any rumors on a 15” mid section, since this motor is so tall I figure a 15” mid would fit nicely on a lot of boats.
  10. #37
    Mar 2017
    redondo beach, ca
    Ok, so that right there is an o2 sensor which tells me this engine IS closed loop. Meaning it will do its best to maintain correct A/f ratio with mods to intake and exhaust. Also the shape of the collected exhaust begs for a water cooled turbo, or remove the alternator and put in a procharger. I will 100 percent be putting in an inline a/f recorder and gauges to see where it's at. During run times. They state that they lean out the engine during cruise for better fuel economy so we already know there is tunability built in.
  11. Likes JPEROG liked this post
  12. #38
    Prince George B.C. Canada
    Quote Originally Posted by 2jz View Post
    IMO yes their will be a 350r 450r n/a. mercury will not make the same mistake twice putting supercharger on this v8 like the did the verado. It's opens the door for anyone to flash ecm for more power something mercury has no control over. A verado 200hp flash to 325hp a 400r flash to 455hp. Mercury will control the hp gains in this v8 with good old proven technique bore, stroke ,cams,intake design. So no v10 also why because its cheaper to add higher compression pistons to get 50hp on 90 octane
    Did you say you can flash a 200 to make 325? For real? I like the sounds of that. What about rpm what can they live with?
  13. #39
    Jun 2014
    Midwest
    Hp
    Quote Originally Posted by whipper View Post
    Would be inquiring as to was data collected off an ISO certified Dyno?
    And what type of endurance testing before and after Flash was Done.
    Nothing reasonable about smoking an outboard powerhead.
    Pretty impressive improvement though.
    In todays ability to Collect rate of acceleration data
    Easy to bring a graph to the table.
  15. Likes whipper liked this post
  16. #41
    Aug 2018
    On a racetrack or at the lake
    The thread below states a 250R actually weighed 564lbs with cowling, has anyone actually weighed a 300R by chance or any new V8?
    http://www.bbcboards.net/showthread.php?t=925606
  17. #42
    Feb 2017
    Naples FL
    My local dealer laughed at me today when asking about the new V8's. He said he might see one in 6 months and the price he gave me was very high.
  18. #43
    Jan 2017
    Albany NY
    Quote Originally Posted by Jamie Nichols View Post
    Mind sharing the price? And for what motor?
  19. #44
    Dec 2013
    georgia
    Mercury has me thinking these motors are build to order something like tesla cars. Talked to a guy this week he doesn't get his 250 motor till March 2019 wth. So I suggested calling Jaco marine they advertise having new v8 in stock his reply is I did they don't have any.
  20. #45
    They have a lot more demand then they ever anticipated. These motors came out at the same time the economy and consumer confidence hit full boost . The big dealers and manufactures are the first to get them Randy has had 4 of the 300R motors but we are still patiently waiting on the offshore versions to be distributed.
  1. New Mercury 300 Pro XS V8 vs 300R V8
    By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-10-2019, 12:00 PM
  2. Some YouTube nonsense
    By Bodhi in forum General Boating Discussion
    Last Post: 02-04-2016, 12:40 PM
