Results 1 to 15 of 24
    Aug 2018
    Livingston, Texas
    Formula 2.4 Value
    I've got a 1980 Formula 2.4 liter MERC on a 20' Sleakcraft tunnel my dad and I bought new. She used to run 92 with the motor jacked up, the rear and passenger seat removed and just a little gas. Since he didn't have much gas onboard, my Dad just floated around waiting for a Bass or Jet boat that wanted to try him haha. Long story short, the boat has been sitting many years and is need of restoration that I'll never get to so I plan to sell it.
    So what do y'all think the motor is worth? The serial number is 5160218, I fired it up the other day and it still screams. Sorry about the sideways pic.
    Mar 2015
    DFW
    serial number pulls up a 1979 200hp. I'd give ya $750 for it if you'd meet me in Waco!
    Dec 2001
    $1500 to va... just a tow away.....2000..... comoin.....
    Florida Keys
    Badass Cowl
    '95 STV "The Blue Goose"
  5. Likes PARKER RABE liked this post
    Nov 2002
    St Leonard Md
    Can you post a pic of the powerhead? Also curious what the numbers on the top of the carbs are...they prob start with a wh
    Ryan
    5 Post(s)
    vertical reed 200
    ST.PETE FL.
    5 Thread(s)
    What a cool classic piece!
    SEEBOLD CHAMPBOAT MERCURY S3000
  9. #8
    Aug 2018
    Livingston, Texas
ID:	417108Click image for larger version.
ID:	417107Click image for larger version.
ID:	417106Click image for larger version.
ID:	417105Click image for larger version.
    Wow, I was hoping for some opinions, I wasn't expecting offers right out of the box! I was always under the impression it was 240HP and the title says 80. I do know it would turn 6200 with a 28" pitch prop. The number on top of the carbs is 1374-5427, here are the powerhead pics. The more I mess with it the more I still love it.
  10. #9
    Sep 2017
    Ashland city tn
    Yep 2.4 200 vertical motor pre 83. Head bolts in sleeve and not the block. Carbs will have a WH 31,WH 22 for example on top of carb ,above or below the number u posted (cant remember exactly. Year model 80 would be the vertical 200, air box dead giveaway,only vertical motor had those types, 225 had the horizontal but was 7 pedal I believe, lots to (go fast) guys do the light weight cowl swap and it looks cool!
  11. #10
    Nov 2002
    St Leonard Md
    I had 1 or 2 of those. They had choke butterflys instead of a primer, no oil injection and no finger ports in the pistons. When mercury switched to propshaft horsepower ratING that motor became the 175. Last one of those I took apart had wh14 on it I think
  12. #11
    minocqua, wis
    92 with stock lower Hmm!
  13. #12
    Aug 2018
    Livingston, Texas
    It’s a 150 lower
  14. #13
    Dec 2011
    Ludington michigan,on the shore
    Will have aluminum flywheel.The heads will have a stamp .100 on the top,they were factory cut,and require 100 octane.The vertical reeds are plastic.Timing was shipped @ 25 degrees.187 preload gear case.would have also came with a blue holly pump,Merc 10,000 rpm tach,and buyers choice of chopper or cleaver prop. $3400 in 1979 Merc called them 240 power head HP.
  15. #14
    Dec 2001
    good Merclover.... Dammm right on the desction good.....
  16. Thanks Merc 2.5 thanked for this post
    Likes Merc 2.5 liked this post
  17. #15
    Dec 2011
    If ya dig deep enough ya find the darnedest things.Click image for larger version.
ID:	418062Click image for larger version.
  18. Likes roadkill636 liked this post
  1. Formula (Thunderbird) Formula One
    By dba900 in forum General Boating Discussion
    Last Post: 10-06-2018, 08:02 PM
  2. Formula SS
    By rgnbull1227 in forum General Boating Discussion
    Last Post: 03-08-2013, 09:05 PM
  3. Formula / Mop VP Hp
    By pfuehrer in forum Technical Discussion
    Last Post: 11-07-2007, 04:19 PM
  4. the formula for mph
    By cbans in forum Technical Discussion
    Last Post: 04-18-2005, 07:02 PM
  5. does anyone know who formula 178 is?
    By MERCMAN in forum General Boating Discussion
    Last Post: 05-02-2003, 10:39 AM
