Results 1 to 6 of 6
Thread: 2.5 225 promax flooding
08-11-2018, 07:47 PM #1
5000 RPM
- Jun 2006
- Ramona Ca
- 270
Just mounted a promax up and when you go to start it fuel comes out of upper manifold flap. I have cleaned and checked fuel pump and tank, rebuilt the vst, injectors were just done by bercato. What else should I look for, I’m all ears. Thanks
08-11-2018, 09:51 PM #2
Float needle in the VST
tux974 liked this post
08-12-2018, 05:10 AM #3
X2 what Capt said! Check needle tip is OK.
Not sure what exactly you mean about flap but it can also could be an injectors O ring not sitting properly in the rail.
08-12-2018, 10:23 AM #4
And the o rings on the two small pipes that feed the rail.
08-12-2018, 03:21 PM #5
All of the above.
RockTeam Junk
08-13-2018, 01:22 AM #6
5000 RPM
- Jun 2006
- Ramona Ca
- 270
Was the o-ring on one of the tubes. Thanks
30 hp flooding
By Bus_Boy in forum Technical DiscussionReplies: 1Last Post: 07-21-2013, 10:26 AM -
Mercury Tech: 2.4 200 Flooding on # 6
By JTchevy in forum Technical DiscussionReplies: 4Last Post: 06-01-2012, 06:07 PM -
EFI flooding?
By rock in forum Technical DiscussionReplies: 1Last Post: 09-05-2004, 01:07 AM -
260 flooding!
By Promax1R in forum Technical DiscussionReplies: 6Last Post: 12-29-2003, 06:19 PM -
flooding
By dwr in forum General Boating DiscussionReplies: 3Last Post: 06-16-2002, 07:37 PM
