Results 1 to 10 of 10
    Mar 2016
    cincinnati, ohio
    triton with 200 merc
    Son is in the process of buying a 2001 Triton bass boat with a 1998 Mercury 200 EFI outboard I know a little about Mercury inlines, but nothing about late model EFI. Supposedly the oil injection pump has been blocked off and you now have to premix, my question is, to do a compression check, is there anything I have to ground, or unplug??? I do not want to fry his new baby. Thanks
    Sep 2017
    Ashland city tn
    Pull all plugs and ground the wires b4 you crank ( couple diff ways of grounding ) throttle wide open
    Mar 2016
    cincinnati, ohio
    Splain the couple different ways
  4. Likes NICE PAIR liked this post
    Sep 2017
    Ashland city tn
    I'm not sure of the correct name,but u can buy the tool,or way I do it is put plugs n wires and wrap a long copper wire something similar around ea plug and ground back to the block. Sry for not knowing correct part name,but object is to keep the spark from jumping around and frying something
  6. Thanks 1954bmw thanked for this post
    Sep 2017
    Ashland city tn
    I believe it's a spark tester they use but I see alot using wire with alligator clips ,,pretty much same method
  8. Thanks 1954bmw thanked for this post
    Mar 2016
    cincinnati, ohio
    Water pump basicly the same, no special tools, special instructions???
    Jul 2012
    Lufkin, Texas
    Yes, water pump will be like the inline.
    For the compression test just ground the yellow/black kill switch wire at the switch box. I just use a short jumper wire with alligator clips. Much easier than a jumper for each plug. This will kill the ignition for the test!
    Josh Peterson
  11. Thanks 1954bmw thanked for this post
  12. #8
    TX......somewhere?
    pull plugs, pull "kill" switch...………. use remote start button at start solenoid.
  13. #9
    Mar 2016
    cincinnati, ohio
    So, Saturday morning met the current owner and went for a little ride, motor started right up and ran great, now the guy is the Previous Owner (PO). He claimed to always used anybodies regular 87 octane gas and only changed the LU oil in the fall at winterization. Do you see any problems or, it ain't broke, don't mess with success????? Thanks guys.
    Feb 2014
    Missouri
    In us all the time. It’s free fine, BUT we all even the “i fish every day” doesn’t.
    When it sits is the problem with e-10. Clean e-free 87 is about the best for just about any outboard but it’s as rare as a goose that lays gold eggs.
    Scope the bore and intake and look at the filter for signs of ethanol damage or rust from water left behind when the ethanol evaporates.
    If stored on land and not kept on the water it’s probably fine and never phase separated, or sat with the bore wet.
  1. Replies: 19
    Last Post: 06-17-2016, 03:12 PM
  2. 14.25x26 hoss triton, small shaft merc
    By Dutch in forum Propellers
    Last Post: 06-09-2016, 11:51 AM
  3. 26 Triton 1
    By Brack in forum Propellers
    Last Post: 08-14-2014, 02:15 PM
  4. 22' triton?
    By speedinstream in forum General Boating Discussion
    Last Post: 08-15-2011, 02:13 PM
  5. Triton Tr-21 PDC
    By KajunBass in forum Props, Setup, and Rigging
    Last Post: 08-04-2002, 07:35 AM
