Results 31 to 45 of 54
  1. #31
    Jul 2011
    Gloucester, VA
    Motor hung to make it easier to swap PHs. Case has a one piece shaft so it will come apart this week and get swapped. Pulled the extension and studs, contemplating if I can cut the water tube in place......
  2. #32
    Jul 2011
    Gloucester, VA
    Also gotta pull the motor back off and re drill the mounting holes..... shaking my damn head....
  3. #33
    Jul 2011
    Gloucester, VA
    The original owner sent me some pictures of the boat in its previous life before the buddy I bought it from got it.
  4. Likes Capt.Insane-o liked this post
  5. #34
    Oct 2005
    savannah,ga
    What kinda fish in pic2? Not much freeboard in pic3!
  6. #35
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by JBS View Post
    Croaker
  7. #36
    Jul 2011
    Gloucester, VA
ID:	414405Click image for larger version.
    Got it all buttoned up last night night
  8. #37
    Lindenhurst, NY
    I bet a 6" set back would make a lot of difference, I used one on my center console and it handles much better. Nice looking set up.
  9. #38
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by 89LASER View Post
    I've though about putting my extra on. Not thos winter but next winter I'm going to close in the stern and put a bracket on it anyway
  10. #39
    Jul 2011
    Gloucester, VA
    And this is the whole reason I got it.
ID:	414462Click image for larger version.
ID:	414463Click image for larger version.
  11. #40
    Jul 2011
    Gloucester, VA
    Couple pics from this weekend. Still chasing down a intermittent running issue.
ID:	414606Click image for larger version.
ID:	414607Click image for larger version.
  12. #41
    Lindenhurst, NY
    When my kids were young, I put down the interlocking multi-colored squares with alphabet letters on the floor. this way if they fell they didn't get hurt. My daughter would pull the letters from the center of the squares and spell words for my son.
  13. #42
    Jul 2011
    Gloucester, VA
    That's a great idea! We have them in the house (hard wood floors) but didn't even think of the boat!
  14. #43
    Jul 2011
    Gloucester, VA
    Got the run issue figured out. Bad ign ecm. Running 44 with a 17 enirtia and 19% slip... has plant of grip on plane and with trim. Cavitates in hard turns even tucked in all the way
    Need to figure that out. Would like to try a 17 or MAYBE 19 rev 4.
  15. #44
    Jul 2011
    Gloucester, VA
    Alright. Got all the stuff swapped over to make the motor a 250EFI. Pulls way Harder. And hits the wall at 5500ish, I could turn the carb set up to 5700 or so. Speed is down (obviously) and still showing 18ish slip.
    So.... should I step up to a 19 or work on getting slip numbers down?
  16. #45
    Jul 2011
    Gloucester, VA
    Thinking I'm hitting the "soft limiter " and the fuel is going full rich.
    Would I be better going up in prop or trying to get slip down?
    Paging @vnemous and @Chaz lol
  1. scored
    By afr in forum Props, Setup, and Rigging
    Last Post: 04-22-2013, 09:15 AM
  2. scored cylinder
    By bigjumd in forum Technical Discussion
    Last Post: 06-06-2012, 10:36 PM
  3. Scored a cherry
    By Jason Johnson in forum General Boating Discussion
    Last Post: 02-11-2010, 10:38 PM
  4. 250 xs #6 cyl scored
    By jimcar in forum Technical Discussion
    Last Post: 02-01-2010, 09:29 AM
  5. scored cyl.
    By CALVIN in forum Technical Discussion
    Last Post: 07-25-2004, 10:28 AM
