Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 54
    Rhode Island
    Quote Originally Posted by RSWORDS View Post
    Yeah work boat racing is a pretty big thing around here.
    Ever seen a wooden Chesapeake deadrise plane out? With enough HP the will lol.
    https://youtu.be/6UDVBD6kjvc
    https://youtu.be/I9_lBqxx85Y
    https://youtu.be/3M0jf1rpaHs
    That 3rd video - Lady Luck... That's some diesel power !!! What do they have in them, big Cat motors?
  2. #17
    Jul 2011
    Gloucester, VA
    Little bit of everything
  3. #18
    Jul 2011
    Gloucester, VA
    Picked up the engine today.... praying it has a two piece shaft to make converting it to 25" easy.
  4. #19
    Dont drop a nut lifting that cowl
  5. Likes nitro_rat liked this post
  6. #20
    Jul 2011
    Gloucester, VA
    Lol
  7. #21
    Okay after the first cav plate, what's going on?
  8. #22
    Dec 2006
    Mt. Laurel, N.J.
    5" spacer
    Azure AZ259, 8.1
  9. #23
    Jul 2011
    Gloucester, VA
    That's the anti-anti-cavitation plate.
  10. #24
    Jul 2011
    Gloucester, VA
    Well, it does have a very pretty looking rod on number one cylinder. It was awful nice of them to put that hole right dead center on the #1 piston so it's easy to see it and inspect it.
  11. Likes nitro_rat liked this post
  12. #25
    Compression relief
  13. #26
    Jul 2011
    Gloucester, VA
    Compression relief
    Just evens up the field for all the yamahas
  14. Likes vnemous liked this post
  15. #27
    Dec 2006
    Mt. Laurel, N.J.
    Turns a 23p 6300 with 175 gears, Slip is like 10%. Also on a 3 1/2" Slidemaster jack plate which I run pretty high. Has stock LWP but doesnt like to turn cause of height I run. Tends to slip in the turns unless you trim down. Fun boat for down here, honestly I'd rather be in the rough water with the Key Largo than the Superboat
    What model is this Key Largo?
    Azure AZ259, 8.1
  16. #28
    Dec 2006
    Mt. Laurel, N.J.
    I'm confused. The Merc you just bought is blown?
    Azure AZ259, 8.1
  17. #29
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by gotboostedvr6 View Post
    Picked it up cheap. Like real cheap. Knew it was blown.
    The hydrostream is gonna sacrifice its power head for the rest the year. When we slow down a bit this winter I'll rebuild this powerhead
  18. #30
    Mama's got a squeeze box
  1. scored
    By afr in forum Props, Setup, and Rigging
    Last Post: 04-22-2013, 09:15 AM
  2. scored cylinder
    By bigjumd in forum Technical Discussion
    Last Post: 06-06-2012, 10:36 PM
  3. Scored a cherry
    By Jason Johnson in forum General Boating Discussion
    Last Post: 02-11-2010, 10:38 PM
  4. 250 xs #6 cyl scored
    By jimcar in forum Technical Discussion
    Last Post: 02-01-2010, 09:29 AM
  5. scored cyl.
    By CALVIN in forum Technical Discussion
    Last Post: 07-25-2004, 10:28 AM
