Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 62
  1. #46
    Jan 2018
    Va Beach
    No doubt this 1708 is THIRSTY ! But not bad to work with once It's soaked.
  2. #47
    Jan 2018
    Va Beach
    No doubt this 1708 is THIRSTY ! But not bad to work with once It's soaked.Off to the store to get more resin ! Lol
  3. #48
    Very strong stuff and you can X the bias if you want.....
    Jan 2018
    Va Beach
    Wetting it outside the boat is brilliant,makes life sooooo much easier.
  5. #50
    Jan 2018
    Va Beach
    All that time for this ! : )
  6. #51
    Jan 2018
    Va Beach
    This is getting real thick real fast.Will 4 layers do the trick ?
  7. #52
    3/16''- 1/4'' is plenty. You might be there now. 1708 is about 1/16''-1/8'' per layer normally. Only place I see needing glass is the area on the hull / transom beside the stringers. Remember, more contact area is stronger. Maybe 1 strip going from the stringer sides going out 2'' past the glass you have on the hull now. May be able to just add the glass when doing knees. Looks good as far as lamination goes. Doing a good job.
  8. Thanks VooDooChild 1267, Laseraddict thanked for this post
  9. #53
    Jan 2018
    Va Beach
    I went ahead and did one more layer that is 90deg from the others.I think i can call it good now and move on......Not sure why i was sweating this so much,it ended up being pretty damn fun.....and it has inspired me to tackle a few more things i was apprehensive about jumping into.ExtremVking,you rock ! I just can't thank you enough for the time you have invested in helping me along.Nothing better then the feeling of doing it yourself for the first time and knowing it is done better then it was.
  10. Likes LakeFever liked this post
  11. #54
    Jun 2018
    Floating around
    Quote Originally Posted by VooDooChild 1267 View Post
    Absolutely. First time, or last time. That feeling only grows. The challenge is make gains, and make them last. Learn from the good and bad, throw out the bad and hang onto the good. Repeat
  12. Likes VooDooChild 1267 liked this post
  13. #55
    Jan 2018
    Va Beach
    She is nice and strong again ! And i am spent !
  14. #56
    Jan 2018
    Va Beach
    Got her out on the water yesterday and all went perfect ! (except for my brand new fuel pump taking a dump) Picked up a bunch of rpm and mph and i am diggin that there is no longer any wiring/cables under the water line.
  15. Likes XstreamVking liked this post
  16. #57
    Jun 2018
    Floating around
    Congrats! Fun thread for me, I learned a lot and enjoyed the show. Does it feel tighter now? How fast does it go?
  17. #58
    Jan 2018
    Va Beach
    ROCK SOLID ! I couldn't be any happier.As far as speed,not exactly sure yet cause there was no gps signal in the area/mountains i was running and my speedo pick-up was kicking into the up position after 75mph.But my 28p Cleaver is now spinning at 6,400 which is a 400 rpm gain for me.Another huge difference was i have had a wiring issues the whole time that i never knew i had (cause everything worked)tell i pulled everything apart to get the motor off,the motor now has real good throttle response (see pic for meltdown)
  18. #59
    Jan 2018
    Va Beach
    I don't remember if i ever posted this pic,but this is how the boat was setup when i purchased it.This was after a 17 hour detail only...They had everything running under the waterline.My favorite
    was the fuel line/clamps and fittings under water exposed.....especially with the amount of debris we have in out waterways.
  19. #60
    Jun 2018
    Floating around
    Ha thats crazy. Good to hear its working great! I dig that mota, would look good on my stream
  1. Ss transome plates
    By tom kennedy in forum Misc. Parts and Accessories
    Last Post: 01-10-2018, 03:53 PM
  2. New Hustler Transome
    By jeepster21 in forum Fiberglass and Composites Discussion
    Last Post: 08-19-2008, 12:33 AM
  3. Has Anyone Done A Full Transome
    By Bed Bug in forum Fiberglass and Composites Discussion
    Last Post: 02-22-2005, 04:08 PM
  4. Ah Oh! Transome problem!
    By 87hydro in forum Fiberglass and Composites Discussion
    Last Post: 07-26-2004, 09:21 PM
  5. Stringer repair
    By CompKing in forum Fiberglass and Composites Discussion
    Last Post: 03-17-2003, 12:20 PM
