Page 14 of 36 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 LastLast
Results 196 to 210 of 530
  1. #196
    Still hate to go around a corner with that pine tree.
    The top of the cowl is only 3 1/2 inches higher then the XS, the block is lighter then the XS, but the gear case is heavier, I don't think the handling will be much different-time will tell, as soon as this water goes down to where we can get into the ramp then its on.
  2. Likes Instigator liked this post
  3. #197
    Sep 2012
    United States
    Quote Originally Posted by engineermike View Post
    What are you looking for here, exactly?
    The power to weight ratio of the STV in the safer and more practical size of a 21' tunnel. I'm 65 and starting to mellow. I hope Mercury marketing is aware of the numbers of my fellow baby boomers and that we grew up on late 60's vee-drive flat bottom boats.
    Bob
    Northern and Southern California
    WL7GS Whiskey Lima 7 Gone Sailing
  4. Likes Instigator, NICE PAIR, AZMIDLYF liked this post
  5. #198
    Mar 2017
    redondo beach, ca
    Good lookin Bob! Is that an old shiada or Hondo vdrive?
  6. #199
    Sep 2012
    United States
    Quote Originally Posted by madmatic View Post
    It is a Magnum which was a knock off (or splash if I understand that term correctly) of a Sanger. Powered by a 392 Chrysler Hemi, water cooled V-drive into a prop pitched for skiing and able to pop up 7 skiers on singles at Lake Tahoe's high elevation (6400'). Top speed 85 mph with the poor Hemi just screaming.
    Bob
  7. Likes Instigator, NICE PAIR liked this post
  8. #200
    Mar 2017
    redondo beach, ca
    Good lord I love those old v drives, balls of steel driving through the chine walk
  9. #201
    Sep 2012
    United States
    Yep, and that is why I want to get civilized with a 21' tunnel.
    Bob
  10. Likes madmatic liked this post
  11. #202
    Sarasota, FL
    Quote Originally Posted by deckofficer View Post
    I like the idea of what your looking for but there is not anything out there that can compare to the ride and performance of an stv in the 21' range. The only hull I can think of would be a 21 Liberator. You will have to special order one built in composite materials with weight savings in the lay up schedule to get a lighter hull and performance your looking for. As far as I know most 21' liberators built to this day are still built with wood. Lighter is faster but also cost a lot more. You may want to consider a 21 twin engine. Randy has built some pretty bad ass twins than run like a champ
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  12. #203
    Oct 2009
    Gonzales, La
    So liberator lists the 21' bare hull at 890 lb, whereas stv listed the euroski at 875. Seems like the 300r on a 21' liberator would be right with it on power/weight. That is....barring ultra light race layup hulls.
  13. #204
    12 Post(s)
    The sound of that motor reminds me when a 200 Merc wasn't really a 200 ��
    What if this new 300 is a bit more?
    From what I think I'm seeing is, Merc caught everyone else sleeping.
    Most of the technology was already here but not to get the weight where it is.
    Last I knew, the mfgs were limited to + 10% of advertised HP's.
    So where as the 300 E-etc is only 278-ish HP, what if the new V-8 is 330.00000 HP's?
    The lightest 4 stroke 8, and probably the least taxed/loaded 4 Stroke on the market.
    Meaning........, what's next ��
    Love it.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  14. Likes specboatops liked this post
  15. #205
    Jan 2017
    Albany NY
    Quote Originally Posted by Hot Shot Merc View Post
    I agree with like a 21 skater with twins, more maintenance with the twins but probably closest you can get to stv performance, that can handle in rough.
    i can’t see a light layup 21 liberator being decent in rough water. But I will say a 21 liberator is the only boat that was in front of me running to the dam. Either he had balls of steel or the 21 liberator is a very good rough water boat, maybe both.
  16. #206
    Love it.
    Mornin G ,
    @ 4.6L they prob had a hard time pulling it back to "only 330"
    I'm sure it will "feel" a lot stronger than it really is . Since most people spend a great deal of their outboard time between idle -5000 rpm , they were smart going with the big inch , long runner , short overlap cam timing .
    It will be just like one of them push button , Max-Wedges ….
  17. Likes Instigator liked this post
  18. #207
    Daytona Fl.
    7 Post(s)
    The 21 Liberator is listed as 890 lbs, but it is NOT. I weigh all my new boats as a bare hull. All the 21's are within 10 lbs of 1075 lbs. All my Liberators have composite transoms and bulkheads. You can walk all over them and have two people lay out on the front deck. The running surface of the sponsons are balsa core for rigidity. The Texas sold Liberators are still wood transoms. I don't know why, but they are.
    Boat Delivery available
    Things owned. NOTHING!!
  19. Likes Hot Shot Merc liked this post
  20. #208
    Love it.
    Lots of careful thought gone into what number to put on the cowl and how much power at the propshaft, I'm sure..
  21. Likes Instigator liked this post
  22. #209
    Sep 2012
    United States
    Azidlyf, who makes that tunnel, lay up, weight, length and beam? We are almost neighbors, I live in a residential airpark just outside Columbus, NM.
    Bob
  23. #210
    Western Pennsylvania
    I'm sure Mercury has the ECU locked down tight making changes impossible until someone breaks in if possible? May even be tighter than our fabulous government email servers.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  1. New Mercury 300 Pro XS V8 vs 300R V8
    By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-10-2019, 12:00 PM
  2. 100 MPH ++ Single engine new boats for new 300R
    By whipper in forum General Boating Discussion
    Last Post: 07-12-2018, 08:14 AM
  3. STV RR/Euro + New 300R
    By Talon 25 in forum General Boating Discussion
    Last Post: 06-16-2018, 09:53 PM
  4. New! Mercury 250R and 300R
    By RUM RUNNER 305 in forum General Boating Discussion
    Last Post: 05-25-2018, 06:02 AM
