Results 1 to 13 of 13
Thread: Real fiberglass expert.
07-14-2018, 09:59 AM #1
Screaming And Flying!
- 15,137
- 416
- 1479
- 6115
- 11813
This guy, i'm sure with good intentions is telling you how to do the super strong method. While he has some of the process right, but incomplete. The rest is a mess.....
. https://www.youtube.com/watch?v=WXtXKadbDwI
07-14-2018, 11:56 AM #2
7000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
fiber glass resin [boat resin]does not bond to old resin. you need epoxy or maybe vyanlester[sp].
07-14-2018, 04:49 PM #3
I made the mistake of pulling up the carpet of my new to me boat....An expert must have done a repair at the stringer/transome.Pounds of cracked resin parting from the original glass,and an equal amount of dry matt in the center of the cracked resin.So not what i wanted to find this time of the season.
Last edited by VooDooChild 1267; 07-14-2018 at 05:03 PM. Reason: Cause some days i can't spell if my life depended on it
07-16-2018, 09:23 AM #4
5000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
That was pretty entertaining. I especially like the cutting wheel being used for grinding. And the way he measured out the resin and MEKP
cooperider liked this post
07-16-2018, 10:03 AM #5
- 15,137
- 416
- 1479
- 6115
- 11813
One of the reply's to the vid asked if he was high...I really got a chuckle out of that....The glass to resin ratio was backwards. 60% resin 40% glass would be my guess. And he had it piled up about 1'' over the surrounding area.
07-16-2018, 11:49 AM #6
Looks like he went to Autozone and picked up the whole fiberglass repair kit. The way the mat was foldes
02-22-2019, 07:00 AM #7
02-22-2019, 07:14 AM #8
- 15,137
- 416
- 1479
- 6115
- 11813
Bottom of the barrell (cheap ortho) resin does have some difficulty adhering to old cured resin. It will delaminate over time. Vinyls and the better polys like the low profile iso's are really needed for laying up over old laminate. Epoxy is king over anything.
Here is a simple guide..http://www.nzfibreglass.co.nz/2015/i...n%20resins.pdf
02-22-2019, 07:22 AM #9
02-22-2019, 07:25 AM #10
- 15,137
- 416
- 1479
- 6115
- 11813
You are using at least a low profile iso resin. They don't sell the cheap stuff at merritts. Your good...
TwzteD liked this post
02-22-2019, 07:29 AM #11
Had me curious, took this from their website, seems to be what you said:
GENERAL PURPOSE POLYESTER RESIN – This resin is a low profile, low shrinkage, unsaturated polyester resin designed for room temperature curing with the addition of an MEK Peroxide catalyst. This system features excellent glass wet out without draining. This system has a moderate gel time and fast cure with a good trim time that allows for cures to a rigid solid, maintaining excellent toughness and strength. This resin is suitable for marine/boat-building applications, parts production, and other general purpose uses. Product is sold by the Gallon, 5 Gallon or 55 Gallon Drum.
02-25-2019, 10:42 AM #12
The Historic Photo Master
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20603
- 5 Post(s)
stream, I watched about the first 20 seconds & clicked off. you tear the matt apart...then he started grinding with all the grindings blasting up his open sleeve... jeeeess loueeeeeez...
03-02-2019, 12:48 PM #13
7000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
you need to fix the structural issues from the backside. then coverup on the top. use epoxy only for a fix this size.
Jay-Need your expert know how
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 01-15-2008, 03:30 PM -
225 johnson expert???
By 225jsn in forum Technical DiscussionReplies: 3Last Post: 07-18-2006, 07:25 PM -
OT. Anyone here a TV/ UHF Expert? Help!
By Jeff_G in forum Electronics, Audio Systems, and WiringReplies: 4Last Post: 01-20-2004, 07:17 PM -
V8 Expert
By PaulO in forum General Boating DiscussionReplies: 1Last Post: 09-05-2001, 09:55 AM
