Page 9 of 36 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 ... LastLast
Results 121 to 135 of 530
  1. #121
    That's just beautiful man.....So many mercs....Like soldiers waiting to go to war.
  2. Likes whipper, vnemous, VooDooChild 1267 liked this post
  3. #122
    Prince George B.C. Canada
    Randy your motor looks unreal cant wait to hear how it runs!
  4. #123
    Daytona Fl.
    7 Post(s)
    I put it on a new red Liberator today. Just gotta wait for the "CLEAN POWER" harness and rigging tube. It's a cable shift motor, but what's cool is that the cables only operate an electrical swith. They don't mecanically shift or move the throttle. That's done by solinoids (I think) It's like new cars.
    Attached Thumbnails Attached Thumbnails DSCN0177.jpg   DSCN0178.jpg   DSCN0179.jpg   DSCN0180.jpg   DSCN0181.jpg
    Boat Delivery available
    Things owned. NOTHING!!
  5. Likes joneill, Blow it up, whipper, 89LASER liked this post
  6. #124
    Feb 2005
    Gig Harbor, WA
    Hey Randy, some height/length dimensions would be appreciated. I plan on installing these on my F26 once the 1.62 lowers come out and am curious how much taller, if any, they will be. They definitely look taller and pretty badass, hopefully run even better.
    Thanks.
  7. #125
    Jan 2017
    Albany NY
    looks awesome Wildman. cant wait to hear some results
  8. #126
    Dec 2006
    Crystal River Fl
    What prop are you considering?
    Kirk
  9. #127
    Sep 2007
    the netherlands
    Randy , do they use the hydraulic steering like the verado on these V8 s ?
    thanks
    bor
  10. #128
    May 2009
    Ormond Beach, Florida
    Quote Originally Posted by bor View Post
    thanks
    bor
    The 300R uses the same type of external steering setup the 300XS uses, either Seastar Pro or Uflex. Only the V8’s with the “advanced” midsection use the integrated Verado style ram and none of those are Mercury Racing versions so they don’t have the SM lower option. They are actually called the Verado 300 and 250. All the other 4 strokes use a traditional midsection that uses the traditional aftermarket steering.
    The 300R HD is also offered with an integrated tie bar wing plate but I don’t have details. Others here probably have more details on that option.
    Mark
  11. Thanks bor thanked for this post
  12. #129
    Quote Originally Posted by mjw930 View Post
    so a bit 80's then....
  13. #130
    Daytona Fl.
    7 Post(s)
    The whole reason they still can use Seastar is to make it easier for people to change over to the new motors.
  14. Likes Spdrcr29, Greg G, bor, Headless Hula liked this post
  15. #131
    Oct 2009
    Gonzales, La
    I suspected that to be the case. I think merc missed out on a lot of repower business with the verado because of the expensive total rerig. I think the Yamaha sho continued to accept conventional controls. That was definitely a factor when I repowered.
  16. #132
    May 2009
    Thats a matter of opinion.
    Mercury has done a real good job of tamping down one of the major flaws of their Verado power steering on single engine application which is massively magnified on surfacing applications. Basically the helm is not up to the task of maintaining pressure on the loaded side of the ram combined with their use of basic motor oil instead of real hydraulic oil means the oil and pump overheat and fluid bleeds past the valves in the helm and you get a lot of noise and constantly have to steer left to go straight. In some situations it actually becomes dangerous as the bleed over will cause the motor to pivot without input in the loaded direction. Not something You want to happen at 100+ mph.
    Dual engine applications don’t have the problem since torque is cancelled between the LH and RH drives.
    In a single engine, surfacing application I would NEVER implement the Verado solution over a Seastar Pro or a side mount aftermarket solution.
    However, there is technically no reason you couldn’t use the Seastar Pro with Power Steering in front of a Verado motor but you would need to change out some fittings and Mercury might have some warranty issues.
    Mark
  17. Thanks powerabout thanked for this post
  18. #133
    Jul 2004
    Lutz, FLorida
    I have no dog in this race but I ride dirt bikes and when they started with the 4 strokes (Doug Henry rode a prototype 4 stroke in an all 2 stroke race I believe. Showing my age now, haha) way back when, they said it would never work. Now they are the mainstream and have more usable torque and power throughout the RPM range. They have also brought the weights down to close to the same as 2 stroke bikes.
    Once the manufacturers get this dialed in it should be ok.
  19. #134
    May 2009
    Quote Originally Posted by engineermike View Post
    Yep, that combined with the option to use cables to get to the e-throttle and e-shift electronics instead of converting to DTS hardware and harnesses should make repowering more palatable.
    Mark
  20. Thanks lance thanked for this post
  21. #135
    Oct 2009
    Gonzales, La
    This is probably worth its own thread (sorry wildman!) and I've researched it quite a bit. The problem is that the viscosity does drop quite a bit and bypass the pump when the fluid gets hot, as you stated. I've learned how to reverse the wheel abruptly to get the internal valve to switch, which locks it in position well....but I shouldn't have to do that.
    All of the hydraulic fluids I've found are lower viscosity than the 0w30 at operating temp so those won't work either. I found an excellent industrial oil that has a very good viscosity curve for the application but the anti-wear package isn't as strong as a hydraulic or motor oil. That leaves the lead case to be a 5w50 synthetic motor oil like mobil1.
  1. New Mercury 300 Pro XS V8 vs 300R V8
    By Skip 7750 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-10-2019, 12:00 PM
  2. 100 MPH ++ Single engine new boats for new 300R
    By whipper in forum General Boating Discussion
    Last Post: 07-12-2018, 08:14 AM
  3. STV RR/Euro + New 300R
    By Talon 25 in forum General Boating Discussion
    Last Post: 06-16-2018, 09:53 PM
  4. New! Mercury 250R and 300R
    By RUM RUNNER 305 in forum General Boating Discussion
    Last Post: 05-25-2018, 06:02 AM
