Results 1 to 13 of 13
07-02-2018, 09:30 AM #1
Junior Member
- May 2018
- Puerto Rico
- 7
Mercury 2005 Saltwater Series 200 HP Carburetor Failure
Hi guys, can some body help me on this matter, I didn't use my boat for almost a year
so I tried to use it during this weekend and found that racor was full of water, then
when i hit the throttle I found that the motor have no power. My guess is that the water
that was on the racor run trough the gasoline system and damaged the carburetor or have
water on it. Can somebody help me on this.
Thanks...
07-02-2018, 11:20 AM #2
Pump some fuel into a bottle and let it settle and take look at it, if it has water ,drain entire system and bowls of carbs
Saulunaproline22 thanked for this post
07-02-2018, 11:55 AM #3
Junior Member
- May 2018
- Puerto Rico
- 7
Thanks, I'll do that. How about the sparks plugs, did I have to change it.
Luis
07-02-2018, 11:59 AM #4
,,it's always good maintenance to change plugs,also when u pull them out ,look for water beads on plugs
07-02-2018, 12:03 PM #5
Junior Member
- May 2018
- Puerto Rico
- 7
Ok, I've been using Champion spark plugs did you recommend this sparks or use the NGK?
Luis
07-02-2018, 12:04 PM #6
For tech tips ,make sure to post in technical discussion, you will get a lot more info over there about any problems. Welcome to scream&fly , great place for anything boating!
07-02-2018, 12:06 PM #7
I'm not familiar enough with 05 model but I'm gonna assume u need ngk. Put up a thread over on tech discussion or search the threads. Probably a faq from lots a folks
07-02-2018, 12:07 PM #8
Junior Member
- May 2018
- Puerto Rico
- 7
Ok, thanks for you help!!!!
Luis
07-02-2018, 12:13 PM #9
I'm assuming your motor is a 2.5?
07-02-2018, 12:17 PM #10
Junior Member
- May 2018
- Puerto Rico
- 7
Correct.
07-02-2018, 12:20 PM #11
Bu8h ngk. I'll double check
07-02-2018, 02:10 PM #12
Do you know if it's a cdm ignition? Also there's likely a sticker on air box or flywheel cover with plug type recommended
07-02-2018, 02:12 PM #13
Junior Member
- May 2018
- Puerto Rico
- 7
I'll have to look at it, I let you know.
Luis
2015 Playcraft Daytona Saltwater Series w/Mercury 250 Pro XS
By Carlson150XS in forum Hulls larger than 20'Replies: 1Last Post: 12-04-2017, 05:36 PM -
2005 Mercury 4 Stroke 115 EXLPT EFI Saltwater
By MERCSPEED in forum Outboard EnginesReplies: 0Last Post: 10-26-2017, 12:21 PM -
Mercury Tech: Rebuilt 125 hp Mercury Saltwater Series Powerhead Break-In
By rickyo in forum Technical DiscussionReplies: 0Last Post: 07-09-2010, 01:54 PM -
Mercury EFI 150 saltwater ECU failure
By motionbroker in forum Technical DiscussionReplies: 0Last Post: 07-08-2006, 09:43 AM
