Page 4 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 46 to 60 of 215
  1. #46
    removed the last remaining wood. Will be grinding the whole area smooth and clean glass
  2. #47
    Jun 2018
    Hudson, FL
    Damn what are people are thinking, why replace something or redesign the transom you're not the manufacturer???? Ok I'll get a hold of myself. Ok Noli I'm watching do this with guidance from the rest of us here.Clean all that out and blow dry it just incase there's water left in the hull. Do you have your materials already to replace that transom? More pics please Geeeez!
  3. Likes noli liked this post
  4. #48
    Jun 2018
    Floating around
    How many beers downed before that plan was hatched? Nasty work, nice to see your going deeper into it but with above posters I dont know how you cant tear into the core and do that at the same time, only have to paint and seal everything once and done, enjoy for life type thing.
  5. Likes noli liked this post
  6. #49
    The powerplants today are so different than when these were first designed then built. I want to cover all bases. If I put a lightweight 2 stroke it would work just fine, but who knows what the next owners would power this with. I'm a software engineer by trade and I follow the principle of have a broad enough solution today so that you've already solved the problems in the future that I wasn't expecting.
    Plus I'm just playing. This Hydro is one of many boats that I will rebuild under one motto...no wood, vacuum bagged...play with carbon fibre...plan the solution three steps ahead of where I am today.
    This is all fun chit, and definitely lots of fun for me. The reason why I do this work on my weekends is because this is actually relaxing work for me. And...i win again...when I finally ride it in open ocean....yes it's a win-win for me.
  7. Likes LakeFever liked this post
  8. #50
    Jun 2018
    Floating around
    I understand that completely, to the tee in fact. My guess is most around here would also agree. I stand by my first post this forum is awesome!~
  9. Likes noli liked this post
  10. #51
    60 pounds of resin and rot in the garbage can. Makes you feel good knowing that crap is out and gone. Three steps out is good planning.....I think you got this very well under control, noli....
  11. Likes noli liked this post
  12. #52
    https://www.screamandfly.com/showthr...T-with-no-core
    well as it turns out, 80% of a Vegas XT hull bottom are....guess what?
    ....have NO core!!!!
    muhahahahahaha! I'm laughing because I'm happy...less work for me
  13. #53
    Jul 2012
    Lufkin, Texas
    As the hull designs progressed PK figured out how to use less core and in regular size sheets so there isn’t nearly as much labor involved to do the bigger boats than to do a Viper or Vector!
    Josh Peterson
  14. Likes noli liked this post
  15. #54
    http://www.hydrostream.org/History.htm
    yes, Pipkorn was a great engineer and production manager
    this pic still blows me away and will never be duplicated by anyone
  16. #55
    Jun 2018
    Hudson, FL
    What the . . . . ? those hulls are gonna be warped! Hehehehe just joking, Noli you need to put a core you don't want a soft boat when you jump a 2' wake from another boat???
  17. Likes noli liked this post
  18. #56
    Jun 2009
    Bristol, Connecticut
    Great work so far...make sure you put a few layers of some new fiberglass on that transom shell before you put the transom in
  19. Likes noli liked this post
  20. #57
    yes, agreed
    the next steps I'm planning are:
    1. thicken the transom skin
    2. make foam core bedding for transom to stand on
    3. install coosa transom
    4. light body work to finish off the transom skin (facing the bilge)
    5. paint or gel the transom
  21. #58
    IMO the transom is the most critical part of any boat construction. This is the place you want to over build. Interesting idea on foam bed. Have you seen it used before?
    I got the idea from cat builders in the size of 32 and 36 footers
    I hang around rich folk, but I am not one ....muhahhaha
  23. Likes XstreamVking, MeCapnDave liked this post
  24. #60
    Reasoning being that it keeps a hard point off the trans trailing edge?
