Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 16 to 30 of 92
    Jun 2018
    Beulaville, nc
    Well, me again. Talked to merc. mech. today , asked about vst tank . He said it wouldn't make it flood...i had a little hope til then. Back at the beginning again
  2. #17
    Apr 2017
    pa
    5 Post(s)
    I agree with post #9. Do you have a merc manual? It would really help you to understand how the fuel management system works.
  3. Likes nitro_rat liked this post
  4. #18
    Sep 2017
    Ashland city tn
    Quote Originally Posted by bullet123 View Post
    x2
  5. #19
    Sep 2017
    Ashland city tn
    x2. I don't own a fuel injected motor but I believe vst has a needle and seat like a carb and if it's stopped up will flood it? Someone plz correct me if I'm wrong
  6. #20
    Jul 2012
    Lufkin, Texas
    Manual:
    http://www.hedges-uk.com/boat/Merc/o...0Magnum%20.pdf
    Josh Peterson
  7. #21
    Jul 2012
    Lufkin, Texas
    Technicians Guide:
    http://www.motooff.ru/assets/files/d...dvigateley.pdf
    CDI Ignition Troubleshooting Manual:
    http://www.cdielectronics.com/wp-con...g-Guide_RS.pdf
    That stuff should point you in the right direction for almost any repair...
    Josh Peterson
  8. #22
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by Kwa View Post
    It absolutely could make it flood with trash in it. But while sitting it "should" not have flow into it. Unless maybe you fuel system isn't venting properly and its putting pressure into the system.
    Remove the VST vent line next time it wont start and see if it have gas. In the drivew squeeze the bulb and see if it pushes past the needle and floods out the vent.
    Something it getting heat soaked while you sit and drink beer.... I mean fish.... Either on the fuel system. Or the ignition. What's fuel pressure when it wont start? Trash in the VST?
    And you need to find a technician not a parts changer.....
  9. #23
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by Merclover View Post
    You're correct. It does
  10. #24
    Jun 2018
    Beulaville, nc
    I checked the vast tank , all looked ok. Carried boat out fishing sat morning. Same thing ran great to fishing spot fished for an hour. No start, flooded , alot of smoke. I checked overflow lines at this time, no fuel coming out of overflow. Fished back to truck.
    Found a guy in New Bern, said he's worked on mercury's for 40 years. They're not merc dealer and no software for mercury, but he wanted to look at it. He said he's seen it all and if he couldn't fix it , he would charge me anything. That's better than all the other places .. so far
  11. #25
    Sep 2017
    Ashland city tn
    Yep, no fix no charge,, worth a shot
  12. #26
    Jun 2018
    Beulaville, nc
    Vst tank and he wouldn't charge if he can't fix. Smart phone ???. Need to proof read better too
  13. #27
    Jun 2018
    Beulaville, nc
    Still waiting to hear from mechanic, must be stumped
  14. #28
    Nov 2016
    Missouri
    I'm with Rock on this i believe you have a bad coolant temp sensor, motor say at 150 degrees and coolant temp sensor only reading like 60 degrees and it will dump extra fuel to and make motor run rich.. I did not see in any of post where this has been checked.
  15. #29
    Jun 2018
    Beulaville, nc
    I'm not sure of anything, maybe this guy knows his stuff. Time will tell
  16. Likes NICE PAIR liked this post
  17. #30
    Jun 2018
    Beulaville, nc
    Hey fellows, me again with update. My 40 year mercury mechanic called sat. to give update. He replayed back to me everything I've been saying all along, floods after it's been run and sits for 30 minutes or so. Yes he does see what it's doing. He has checked and rechecked everything that has already been checked and rechecked. Don't have a clue what is causing it to flood. He's checked fuel pump,diaphragm, vast, vents, checkvalves, stator,spark,fuel pressure, ecu. So, what do you do now??
  1. I'm afraid to ask - too little oil was mixed
    By Stoker1 in forum Technical Discussion
    Last Post: 04-03-2014, 07:31 AM
  2. Why arn't you afraid of me ??
    By mmassm in forum The Scream And Fly Lounge
    Last Post: 04-24-2011, 09:30 AM
  3. We're Not Afraid.....
    By Jay R. in forum The Scream And Fly Lounge
    Last Post: 07-17-2005, 10:15 PM
