Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
    minocqua, wis
    carson reed stuffers
    anybody running them ,results ?
  2. Likes phillnjack liked this post
    bump
    Nov 2016
    Missouri
    Curious as well.
    Nov 2016
    Missouri
    I was thinking of buyin stuffers and reeds next month and was hoping someone would chime in.
    Feb 2011
    HUDSON, FLORIDA
    risYeah me too...its like nobody has tryed em? c
    Jul 2012
    Lufkin, Texas
    It’s gonna provide the same results as cutting the front, but without the machine work...
    Josh Peterson
    Mar 2017
    ohio
    got the stuffers and reeds in a 300l promax with a special tuner.runs strong and idles good.
  9. #8
    Sep 2015
    Twin Cities, Minnesota
    There's not much if any technical data on them yet that says exactly what they do, how they do it and if there is a gain in performance. I'll wait for the testing results to be posted.
  10. #9
    Jul 2012
    Lufkin, Texas
    They push the reed blocks further into the crankcase thus reducing the volume thereof or providing “stuffing.” I suppose one could drop a set into a calibrated container and measure their volume. The amount of stuffing would be far easier to quantify than the amount gained by trimming the front half say .050”!
    Josh Peterson
  11. #10
    Jul 2015
    northern lower michigan
    I just ordered 2 sets for my 250 efi"s twins with reeds. I think Chris told me there 0.65 thick. And he did say that the 3.0 ones have only been out 3 weeks so he's waiting for feed back.
  12. #11
    Nov 2016
    Missouri
    Me and probably a few on here don't know what performance gains of even trimming the front half is...is it more lower end , mid range or top end performance?
  13. #12
    Jul 2012
    Lufkin, Texas
    I’ll let Jay Smith explain a little about stuffing:
    Quote Originally Posted by Jay Smith View Post
    Stuffing is normally done with a special grade of epoxy to equal an intake track that for some reason has more volume than another ( such as the one cylinder that has the oiler gear cavity in it )or to boost the crank case pressure to enhance the vapor speed . With more crankcase pressure the vapor picks up speed and creates a faster transition from reed to piston . Once the motor is equal in its volume from bore to bore one can take material off the front half to equally boost the compression and speed on all intake tracks. Care must be taken not to cut to much off as the reed will contact the rod bolt as the rod cycles and moves to BDC. All 2 cycles will see a performance enhancment with this mod done as long as one relizes that the weak link in the equation is the reed itself . The reed can only stand so much pressure and if over loaded with too much crank case pressure it will prematurely fail. With the reed failed the intake charge that carrys antidetonation propertys and lubrication is now allowed to back up into the air induction portion of the motor not getting to its intended destination the piston top , the motor now runs lean and will soon loose that piston !
    Hope that helps,
    For FAR more information on this topic a simple seach of this site will turn up volumes of information...
    Josh Peterson
  14. #13
    Apr 2017
    pa
    5 Post(s)
    It also moves reeds farther away from injectors/carbs, which gives better atomization. What does a set cost?
  15. #14
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by bullet123 View Post
    According to Chris:
    Quote Originally Posted by Chris Carson's Marine View Post
    7 petal 85$,5 petal 75$,4 petal(much thicker)85$
    Unless you have free access to a mill it's the best thing going...
    Josh Peterson
  16. #15
    Apr 2017
    pa
    5 Post(s)
    My front is cut .050. Why are 4 petal thicker? I’ve never measured, but it seems the 4 petal cage is closer to crank already.
  1. Help explain reed stuffers on a v4 crossflow
    By spybot in forum Technical Discussion
    Last Post: 09-12-2017, 07:42 AM
  2. 7 petal reed cages with Chris Carson Race reeds
    By moomba in forum Misc. Parts and Accessories
    Last Post: 10-30-2015, 10:02 PM
  3. OMC Tech: Another Reed Question for Chris Carson
    By groundloop in forum Technical Discussion
    Last Post: 05-21-2011, 11:46 PM
