Page 3 of 3 FirstFirst 1 2 3
Results 31 to 42 of 42
  1. #31
    Sep 2015
    Twin Cities, Minnesota
    Quote Originally Posted by CUDA View Post
    Another thing we do is only use 24v for the trim computer and 12 for the steering wheel switches , when your at speed and hit the trim switch you only need a little adjustment , we are talking light race boats that react very quickly, not heavy lake boats, in a light boat at speed you can get hurt in a hurry with 24v
    it is so much quicker. When I say trim computer , they are timers that have a switch behind the foot throttle,
    you add the delay that you need for your set up, somewhere between .5 to 1 or so seconds for a V bottom then you have run time for the trim pump.
    we start with the motor tucked in, floor it, run your set delay time , then run time , then some bump the up switch a hair more to get a set, v bottoms more so then tunnels.
    I was going to buy one of those
  2. Likes WillySteve liked this post
  3. #32
    Nov 2001
    St Mary’s GA
    I’m in the market for a new pump, so which is the best and fastest pump to buy, for drag racing?
  4. #33
    PARADISE /Naples
    hear you go
    http://www.racedigitaldelay.com/
    I use the 95
  5. #34
    Jun 2008
    Sardis Lake Oklahoma
    Quote Originally Posted by Mirage View Post
    Can't go wrong with a Mercruiser pump!!!
    WillySteve Hendricks
    20XDC Bullet/Modified Merc 260
    295TF Charger/ProMax 225x-Sold!
    '83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
    '85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
    Freedom 240 DLX Fisher Toon/Merc 115
    10' Cougar Cub/Merc 25HP On The Bottle!
    18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
  6. #35
    Mar 2010
    houston, tx
    I have the good mercreuiser pump on one of my boats and a bobs backplate pump on the other one
    the bobs is a little faster and lighter and way cheaper. I like it better.
    You have to get an adapter fiting to make it work. Jic to an if I remeber correctly.
  7. Likes WillySteve liked this post
  8. #36
    Nov 2013
    Oak Hill Fl.
    I don't get the timer thing.
    Why not just put a adjustable micro switch on the trim gauge and use a latching relay? way cheaper and you know it will stop at the same place no mater what.
    Will post my set up here soon when I get it hooked up.
  9. Likes ironhead stv, Krazymaan liked this post
  10. #37
    Mar 2010
    houston, tx
    Quote Originally Posted by dwilfong View Post
    Thats basically the way it was done before trim computers, some still have a stop switch onna mechanical gauge Incase a solinoid Lock’s up etc.
    one of the big benifits tk the computer is how fast you can adjust it, different wind, current water conditions etc take different settings.
    We are changing the settings constantly testing and running usually
  11. Thanks Hot Shot Merc thanked for this post
  12. #38
    shreveport,la
    Trim timer handles delay too
    Erik Kiser
  13. Likes 90 5.0, WillySteve liked this post
  14. #39
    PARADISE /Naples
    WHAT you looking for consistency !
    sounds like cheating to me.
  15. Likes WillySteve liked this post
  16. #40
    shreveport,la
    I have no desire to drive my boat without a trim timer. It's pretty much required equipment
    Erik Kiser
  17. Likes 90 5.0, Hot Shot Merc liked this post
  18. #41
    Mar 2010
    houston, tx
    Quote Originally Posted by patchesII View Post
    When I stopped racing my bassboat and put it back to full tournament load again I left my trim computer in it and use it all the time still, especially for tournament blast offs lol.
  19. Likes WillySteve liked this post
  20. #42
    Sep 2002
    Solvang, Calif
    Smile Not a racer, so I can share.
ID:	404651Click image for larger version.
    First pic is how i used two batteries for 12 volt boat and 24 volt trim. This circiut when at rest allows the charging system to charge both batteries. Just acts as a large 12 volt.
    Second pic is (1) how I connected to a 3 wire trim pump (isolated ground circuit). 2. The three different voltages that can be used to run the pump. (3) The Pulse Modulated variable voltage so I could drop the speed of the trim to allow trim adjustment on the fly.
    Gary
  21. Thanks dwilfong thanked for this post
    Likes dwilfong liked this post
  1. Replies: 5
    Last Post: 12-31-2015, 11:43 AM
