Results 1 to 8 of 8
Thread: identify this part!
04-09-2018, 02:22 PM #1
identify this part!
jus when I thought I probably seen every part for tha 2.0, 2.4, 2.5 (pre cdm and non opti's) this shows up.. anyone every run across this?
http://texasfishingforum.com/forums/...n#Post12708828
04-09-2018, 04:15 PM #2
Never seen that before. Like you said just when you think you have seen it all.
04-09-2018, 04:22 PM #3
its not on any parts or water flow diagrams that I've ever seen either.. maybe shows on some old timey (my day) microfiche???
04-09-2018, 05:15 PM #4
Sent the link to George Fuller, he also has never seen one like that. Thinks it is not factory.
04-09-2018, 07:22 PM #5
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,352
- 9
- 265
- 31
- 732
It Is a factory piece, used in some of the earlier vi sixes, years ago I have seen them in a couple of different motors. Don’t really remember what they did, but I’m sure it is a factory part, Also, be assured it came around way before the water cooled regulator, Chris
Dave Strong liked this post
04-09-2018, 07:52 PM #6
had a number of early v6 with design one, two and three poppets and never saw it.. if it its oem, part of tha coolin' system, inside tha motor then it would be listed somewhere.. jus my way a thinkin'.......
04-09-2018, 08:19 PM #7
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,352
- 9
- 265
- 31
- 732
Very confident that it’s a factory part, I remembered plugging in to the blocked off small cavity by the buffet valve, and the motors it was used in that cavity was not blocked off, Chris
04-09-2018, 08:41 PM #8
its in an '89 xr4.. no reason for it not to be listed and/or discovered by many if used in production by then unless it was jus added.. doesn't really make any difference since he can't find a new one he's jus gonna re-use tha one he's got...
but it is MERCURY sooooooooo anything is possible... who knows?... kinda like tha laser injected bridge port I picked up several years ago.. no diagrams/part numbers listed anywhere for it..
can you identify this part on my drive?
By markt111 in forum Technical DiscussionReplies: 3Last Post: 05-10-2015, 09:17 PM -
Please help identify this part
By gusgus in forum Technical DiscussionReplies: 9Last Post: 08-20-2012, 04:44 AM -
Mercury Tech: Help identify this ignition part
By rdkvector in forum Technical DiscussionReplies: 4Last Post: 11-04-2010, 04:13 AM -
Help -identify Part/bracket
By liberatorx2 in forum General Boating DiscussionReplies: 2Last Post: 05-26-2003, 09:27 PM
